Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Events > Past NAXJA Events > PAST NAXJA EVENTS > Sierra Fest 2019
Sierra Fest 2019 August 5th - 11th. The Rubicon the 5th-7th, then heading to Hermit Valley the 8th-11th.
Old April 18th, 2019, 15:19
#S194's Avatar
#S194 #S194 is offline
Sierra Chapter President
Minimum Vehcile Requirements for Rubicon
Minimum vehicle requirements for the Rubicon portion of Sierra Fest:
33"+ tires
At least 1 FULL locker
If you have stock steering you must carry spares
No D35's or 27 spline 8.25's unless you have multiple spare axle shafts and knowledge to change them.
Spare parts including spare D30 shafts, drive shaft u-joints, spares for whatever non-standard parts installed on your rigs, a full set of tools and the knowledge to use them.
Mini skids or reinforced LCA brackets, a t-case skid, and a gas tank skid HIGHLY recommended. These are things that are REALLY HARD to fix on the trail!!
PLUS the equipment required according to bylaws:
1. Visibly charged fire extinguisher (BC or ABC)
2. First aid kit
3. Adequate spare tire, jack and lug wrench
4. Safety belts for driver and any current passenger
5. Adequate attachment points in the front and rear of the vehicle:
a. Acceptable forms of attachment points: (All Items must be mounted in a manner to provide adequate strength and integrity)
b. Tow hooks of OEM or greater integrity
c. D-Rings
d. Shackle/Clevis
6. 20ft 10,000lb snatch strap without any metal hooks
7. Secured battery (no bungee cords)
The minimum requirements are there to ensure we have as few hang ups as possible along the trail. Can you run the Rubicon on 31's and a D35? Yes you can. But this would make for a very long weekend if we dealt with multiple breakdowns along the way with a large group.
These minimum requirements are there to make sure everyone has a good time wheeling and not have it turn into a wrench fest.
Originally Posted by GordoSmasho View Post
Tim's junk is impressively beefy. TWSS
Rate This Thread:
Minimum Vehcile Requirements for Rubicon #S194 Sierra Fest 2018 3 July 30th, 2018 17:57
Minimum Vehicle Requirements for Rubicon #S194 Sierra Fest 2017 0 May 29th, 2017 20:13
Minimum Requirements HaleYes WinterFest 2010 63 February 5th, 2010 14:21
Minimum Requirements HaleYes WinterFest 2009 16 March 3rd, 2009 12:12
Minimum requirements for Rubicon seymouj Sierra Chapter 3 July 11th, 2003 19:43
