kelleybean88
- Richmond, VA
Hey everyone im new on the board and desperatelly in need of some info... I was refered to you by a part company in Washington...
Dilema:
Last weekend did an axle conversion on a 1996 cherokee. We used an axle out of what we believe to be an 88 cherokee. But we chose to put the 96 axle shafts back into the axle. Now the axle is leaking and I have read that it is because the axle shafts are a smaller diameter than the 88 2 piece axle shafts. I have been searching all over the place for the seals to correct this problem but the part numbers I keep finding dont match up to any parts. Do any of you happen to know the part numbers of the seals to fix this problem? I am supposed to go wheeling this weekend but cant go if I dont fix this leak.
Dilema:
