Driveshaft hitting exhaust downpipe
sportsguy
Here's the scoop:
1989 MJ - 5" in front, 6" in back
Last time out the grease nipple on the ds slip yoke ripped a hole in my rusty ol' downpipe.
This time, the grease nipple lost, the downpipe survived, but in addition to the nipple hitting, this time the u-joint ears (DS end) put a mighty dent into the downpipe too.
Static, the clearance is roughly 1 1/2" between the ds and downpipe.
(For those who may not know, the downpipe comes from the mainfold, down, then turns back (runs parallel to the ground for a bit), then crosses towards the pass side of the truck.)
The grease nipple is hitting the flat (parallel to the ground) part, while the u-joint ears hit the section just before this (and the bend) coming down from the manifold.
What's the solution?
Happy to provide any missing details.
sounds like your front end is walking when flexing. Mine did the same only it hit my skid plate and I wasn't too worried about it. Check all your bushings/joints for play. Other than that, I don't know what esle to tell you.
i had to take a grinder to the flange on mine, as that is where my DS was making contact...
XJ Adjustable Track Bar ..$129.00
Made from solid stock for XJ's lifted
2 to 4.5 Inches
Perhaps I'm over 4.5" up front and it's causing the front end to walk a smidge?
Bumpstops my friend - your axle moves to one side while flexing, think about it for a little bit - There is a link from the axle to the frame and the axle pivots around the ends of that link -
when flexing up the left tire - the right end drops and the axle moves to the passenger side...
At least that is all that i can deduce about my problem...
The down pipe on my STOCK Comanche has a big ole dent in it near the manifold mount flange...this was from running over a curb...guess I'll add bumpstop..
I had this problem due to DW after I first installed my lift. Took a while to solve the DW problem but in the mean time, the pinion on the front axle tore a big 'ol hole in the down pipe every time the axle danced. This is how I fixed that particular problem:
Now THAT is a solution I can really like! Thanks a bazillion, man. :)
