For Sale: Jeep Front Dana 44 High Pinion Project - 4.10, Lock-Right, XJ, TJ, ZJ
Finish my project!
I was building up this front Dana 44 for my Jeep Cherokee, but I decided to go with something else. Axle is complete and comes with all required parts to bolt on to a Jeep XJ, TJ, or ZJ. The only things that need to be done are welding on the suspension brackets and a gear setup, which are all included. I have over $1500 in this project and I'm looking to get something fairly close to that. But, willing to negotiate. Make me an offer!
Features:
-Ford Front Dana 44 Differential - high pinion, reverse cut gears - driver side diff ('79 F-250 SD i think)
-Full size - about 67" WMS to WMS (use custom backspaced wheels if need be)
-30 spline axle shafts with 5-760x u-joints
-Ford flat top knuckles - can be drilled and tapped for hi-steer or use OTK setup
-Rotors, Spindles, and hubs - like new
-HD External Warn Premium Hub Lockouts
-Massive Dual Piston Brake Calipers with new pads
-4.10/4.11 Precision Gears
-Powertrax Lock-Right Locker installed
-New Heavy Duty Rubicon Express Upper Control Arm Bracket Kit, Spring perches with shock mount and Lower Control arm brackets
-Sandblasted, primed, and painted flat black
-All parts have been sanded and painted
I am located in Santa Barbara, CA 93117. Shipping is available via Forward Air Freight. If you live in CA, come pick it up and save on shipping!
Here is your chance for the upgrade you've aways wanted to do, but never had the time. I've done all the tough work for you! Just get the brackets welded, setup the gears, and you are ready to go! I looked at getting a pre-built custom front D44, but the places wanted anywhere from $5k-$3k. Don't miss out on this value!
Email me with any questions:
[email protected]
Finish my project!
Features:
[email protected]
