(2) 10" Fox 2.0 Smooth Body W/ Reservoir & (2) 8" 2.0 Emulsion
crystalcleanteam
These were put on a truck then Changed the lift and pulled off. Driven on the street a few times never offroad. Trade for ? Willing to ship in USA
(2) 10" Fox 2.0 Smooth Body W/ Reservoir $170 Each
Valving 30/90
Body: Smooth-bore, clear coated, zinc plated, honed seamless alloy bodies
Components: Black anodized 6061-T6 billet aluminum
Shaft: 5/8" hard chrome plated heat treated alloy steel
7/8" hard chrome plated stainless steel 17-4 H900
Piston: Race-developed high-flow piston design
Valving: Proprietary deburred valve shims
Seals: Redundant sealing pack system main seal, wiper seal, scraper seal
Optional high temperature Viton seals
Oil: Specially formulated for ultimate performance at variable temperatures
Reservoir: Remote
Mounting: Teflon-lined, heat-treated, alloy steel spherical bearings - 1/2" bolt x 1 1/4" wide
Optional spacer x 1 1/2" wide
Adjustments:
Nitrogen pressure
Compression valving
Rebound valving
(2) 8" Fox 2.0 Emulsion - $125 each
Valving 40/60
Reservoir: Emulsion
Adjustments:
Nitrogen pressure
Compression valving
Rebound valving
