Old October 15th, 2007, 14:08
fuzzydog fuzzydog is offline
Wide track AMC 20 rear axle swap in...?
Someone talk me out of this insanity! I've done a lot of searching on the net these days for AMC20 info and I bet that this subject has the most conflicting info on the whole intardweb!
I just picked up a basketcase 1980 Chero Chief with widetrack AMC20 and D44 in the front. i really just wanted a D44 front, but I do want to go full width into my 1990 XJ.
So I have the D44 for the front, but it has 6 on 5.5 bolt pattern. My rear 8.8 has 5 on 4.5 pattern, so why not slip in the widetrack AMC20 while I'm at it?
First of all this is a Chero AMC20, not a CJ so it has the one piece axles and (reportedly) thicker tubes.
A quick look at Randy's R&P and I can get 4.56 or 4.88 R&P and ARB locker for the AMC20.
Never mind the get a Dana60 spiel - I do not want that big of an axle.
Tire size will go up to 35 and possibly 37's.
So, why shouldn't I do this?
Old October 15th, 2007, 14:15
unclethumbtack unclethumbtack is offline
Re: Wide track AMC 20 rear axle swap in...?
I just got rid of a W/T Cherk and the amc 20 in them is just as strong as the 44 I welded mine and and stitched the tubes and ran 35's hard, never had a problem.
Old October 15th, 2007, 14:49
That's what I like to hear - real world, this is what I did type of experiences. Thanks for the input unclethumbtack (I bet there's a story behind that nickname...?)
Old October 15th, 2007, 17:33
DaveW's Avatar
DaveW DaveW is offline
I'm running a 20 Metric ton from an MJ. I am the second owner. It worked well with no problems for the first owner and has been great for me. Both of us have run 285-16s.
I got it after talking to another M20 owner. He never had a problem running 35s.
Yes, the axle tube is larger (if I remember 3") than the CJ version.
Just be ready to dump a bunch of gear oil in that baby.
Old October 15th, 2007, 18:00
If you want to know everything you could ever know about the amc 20 go over to ifsja.org and search amc 20 strength. It's an ongoing battle.
Old November 4th, 2007, 13:40
Comanchedude's Avatar
Comanchedude Comanchedude is offline
I run the factory AMC20 that came in the MJ (or some say its really a 23) in my MJ
I have it locked and running 33" tires now and I do push it very hard I dont have any worries.
just get a real diff cover like the one I have, the factory one is really a joke and wont take any abuse at all..none
Old November 4th, 2007, 17:02
lancey3's Avatar
lancey3 lancey3 is offline
wow what a cool lookin axle.
Old November 4th, 2007, 17:03
lancey3's Avatar
Old November 4th, 2007, 22:11
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
I had a 20 in an 83 Chero W/T... good axle. Very different from the CJ one which has the bad rep.
I'd run it, almost kept mine for the axles for my XJ.
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Wide Track Rock Sliders DrSockMonkey NorthWest Chapter 18 April 23rd, 2007 14:09
How wide is my rear axle? zfinger OEM Tech Discussion 3 April 17th, 2007 11:31
waggy wide track dana44 shafts? ktm racer 419 Modified Tech Discussion 4 December 17th, 2006 13:25
Rear axle swap hemihead Modified Tech Discussion 8 September 7th, 2006 19:48
Wide track dana 44 in Cherokee XJ dana44 Modified Tech Discussion 10 May 30th, 2003 02:32
