Old December 26th, 2004, 21:09
Purple's Avatar
Purple Purple is offline
Unhappy Transfer case help needed:( Please help ASAP :) Thanks
Hey, new here, from Ontario, Canada, would like to say HI to everyone,
I own a 98 XJ 4L auto, not my choice on the tranny, but got it at a killer deal and had to get it anyway Hi once more... here is my actual question...
I have lifted my XJ using Teraflex's SX4L kit... and thats 4", im experiencing vibrations, and i have driven my XJ like that for about 300km, im figuring my ujoints are shot already. Anyway, going to drop my t-case. But... on the way undooing the second bolt on the driver side, i have noticed that it is not a bolt, but a nut, what i did to remove that threaded pin was i welded a nut on it, and started unscrewing that. By doing that i got it almost out, but at the end it just started turning, and the threaded part that sits inside the frame got loose... (my t-case crossmemeber still sitting on the jack-axle stands).
What do i do now?
Old December 26th, 2004, 21:10
Purple's Avatar
Re: Transfer case help needed:( Please help ASAP :) Thanks
What are the other options, as for vibrations? What else could it do?
Old December 26th, 2004, 21:27
Purple's Avatar
What is the BEST possible way to go? i have heard that dropping the T Case is not a way to go because the level of ATF changes in Automatic Tranny, and then it dies sooner then later...
Old December 26th, 2004, 21:54
90KrawlerXJ 90KrawlerXJ is offline
NAXJA Member #1067
Try a rear SYE (Slip Yoke Eliminator on the xfer case), and a C/V constant velocity driveshaft. You didn't mention what kind of terrain your XJ encounters. I would recommend replacing the light duty NP231 anyway.
Old December 27th, 2004, 05:46
XJJPR XJJPR is offline
First to fix the nut. You can either go in from the top, inside the rig or if it is close to one of the larger holes in the frame you might be able to start a new one with a nut behind it. Sometimes you can tack weld a nut back into place from the outside by grinding a small groove in the sheet metal and hitting the nut on the side welding it back to the sheet metal where you made the groove.
4" on a 98 you'll need a sye for sure. Go with a AA or other HD kit, forget about the H&Ts, not worth the time.
If you drop the tcase check and fill the tranny level after you do it. At the right level it should be fine.
hinkley
Old December 27th, 2004, 09:28
Purple's Avatar
Unhappy Re: Transfer case help needed:( Please help ASAP :) Thanks
Thanks a lot guys, unfortunately i have to have the vehicle on the road in about 2-3 days for the new years. We got a cabin, and there is 10 people comng. Anyway, that is what i wanted to do (SYE) and CV driveshaft.
Question would that help if i did only the driveshaft? or not?
As for what i do with my XJ, nothing, daily driver, i had a YJ before and went through 3 engines and d3 trannies offroading some contributed to amazing pics.
Anyway, thanks a million.
D.
transfer case woes,.. BILLXJ Modified Tech Discussion 15 May 24th, 2005 14:25
Transfer case spline count info wanted. lunghd OEM Tech Discussion 4 May 2nd, 2005 18:54
Transfer case needed JeepsterXJ Wanted: Private Party Only 9 September 25th, 2004 19:38
transfer case linkage fabrication ideas,.. bxj Modified Tech Discussion 7 June 22nd, 2004 08:14
Repairing Cast Aluminum Transfer Case BrianJr OEM Tech Discussion 5 January 12th, 2004 10:41
