Old March 22nd, 2019, 09:18
CLSegraves CLSegraves is offline
Voltage Gauge read 19 volts - Digital Meter says 14.2
2001 XJ, 4.0 with a 160 amp Durango Alternator that idles at 13.8VDC (confirmed with volt meter). 3 month old Optima Yellow top battery. Battery, alternator and ground (both from battery to frame and frame to engine block) cables are 2/0 gauge audio grade cables. No cranking issues. I've been running this setup for almost a year without any issues before now.
Yesterday I was driving home and the voltage gauge in the cluster pegged at 19VDC. I was on the freeway so it took me time to get off and get to where I could stop. By the time I did, the gauge had returned to normal. Started driving home and it happened again (19VDC while cruising, back to normal on stopping).
This morning I hooked a digital volt meter to the battery (my battery is under my rear seat) and drove to work. As expected, got on the interstate and the voltage gauge pegged at 19VDC. Volt meter confirmed rock solid 14.2VDC the entire time. When I stopped, the volt meter showed 13.8VDC and the voltage gauge returned to normal. This indicates to me that the alternator, voltage connections, and battery are good. So I'm at a loss.
Any input?
Old March 22nd, 2019, 09:39
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: Voltage Gauge read 19 volts - Digital Meter says 14.2
Sounds like a loose ground at the gauge/cluster/harness.
Old March 22nd, 2019, 10:24
Any idea where the garage cluster grounds?
Old March 22nd, 2019, 10:59
cal's Avatar
cal cal is offline
Not a clue.
Old March 22nd, 2019, 11:09
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
The OBD-II PCM will trip the Check Gauges light and flip the voltage gauge to either end of the scale if the PCM notes a charging problem.
If the dashboard voltage gauge shows 9 volts there is almost always an alternator issue. If the dashboard voltage gauge shows 19 volts, there is almost always a connectivity issue, often corroded battery lugs/terminals, internally corroded battery wires, or a loose connection in the charging system. Make sure the battery charging temperature sensor in the bottom of the battery tray is not malfunctioning, and that the battery sensor wire plug and wire harness are not damaged or corroded.
Gauge cluster grounds are unlikely to be the root cause of the issue.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old March 22nd, 2019, 11:19
If the voltage gauge shows 9 volts there is almost always an alternator issue. If the voltage gauge shows 19 volts, there almost always a connectivity issue, often corroded battery lugs/terminal, internally corroded battery wires, or a loose connection in the charging system. Make sure the battery charging temperature sensor in the bottom of the battery tray is not malfunctioning, and that the sensor wires/wire harness are not damaged
I cut the battery temp sensor out (coiled the plug and wrapped it into the harness to prevent a short) months ago when I relocated the battery. Perhaps that’s the issue (I’d be surprised it just now started complaining)?
Old March 22nd, 2019, 11:20
Should say “CUT the plug” (not coiled).
Old March 22nd, 2019, 19:01
techno1154's Avatar
techno1154 techno1154 is offline
There are a couple of things that do not add up.
You cut the battery sensor out? My 1996 XJ will immediately turn on the check engine light it is disconnected. Maybe the 2001 is different.
An independent volt meter connected across the battery shows 14.2 volts when the engine is up to speed. I would say that is a perfect voltage reading. The aim is to get 14.3 to 14.5 volts.
I think you need to look somewhere else outside of the alternator and/or the PCM for the high voltage reading on the gage. I agree with Cal. You may have a grounding/wiring problem going to the gages. Those could be difficult to trouble shoot.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old March 22nd, 2019, 21:29
Yes, I cut the battery sensor out and it's entirely possible that it has thrown a code. However, my check engine light has been on for almost 2 years now ever since I swapped in the manual transmission (the ECU is still an automatic ECU). I haven't attempted to "fix" the issue as I'm planning an LSx swap by the end of the year.
That was my feeling (that the alternator is working as it should based on the 14.2 VDC). Interestingly (thinking about my issue tonight), after I went wheeling last weekend. On the way home, I started getting "glitching" of the speedometer. I'd be driving along and the speedo would suddenly "bump" up or down, hold, come back to actual speed. This glitch would happen every few minutes, but this issue hasn't returned since we got home. I'm wondering if this could also have been from a lose/poor ground in the cluster.
Old March 23rd, 2019, 03:17
indian's Avatar
indian indian is offline
You have to plug the BTS back. I had this issue with my 2001 also. The ECM needs the temperature signal to calculate the charging depending on 'battery' temperature..
Old March 23rd, 2019, 10:49
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
You can scan the OBDII port to see if the battery temperature sensor is throwing a code, among other the codes.
Guess your state doesn't doesn't require emission testing. A lighted CEL light would be an automatic fail in states that test.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old March 23rd, 2019, 10:54
RCP Phx RCP Phx is offline
Yes, we do. I would have to assume this rig has not been on the road.
Old March 23rd, 2019, 21:29
I hooked the battery temperature sensor back up this afternoon and drive the vehicle. Same result as before, so it's not the lack of a sensor that was the issue (didn't think it was as I had been driving the vehicle this way for the past 6 months).
We do have emissions here, I'm just between tests (not due again until Feb 2020). I'll either fix the issues or do my LSx swap before it comes up for testing again.
Old June 5th, 2019, 21:05
BAXJDAY BAXJDAY is offline
Was this resolved? My '97 XJ has started the same bad behavior.
I've tested everything. Battery good at 12.7v, BTS draws 9k resistance (fairly new also), all connections good and clean, new alternator 3 months ago.
I disconnected my winch cables and compressor circuits to eliminate any issues there. Checked all my fuses and breakers, eliminated my bad auto door lock circuit by pulling the fuse. I had a spare PCM, finding out the voltage regulator goes bad on those, I swapped out my spare. Still the same problem.
If I have to troubleshoot the gauge, I'll leave that to the experts. But any other ideas I might be overlooking? I'm about to tag out.
Old June 5th, 2019, 21:40
I should mention that the voltage test at the battery while running is consistent with the gauge reading. 14.2v upon start, 19.3v when acting up. Which makes me think the gauge is OK and reliable.
Volt meter = 12 volts for a minute then ~9.5 heyisforhumans OEM Tech Discussion 2 October 10th, 2015 00:12
wiring a tach, temp, and volts gauge. mxracer5647 Modified Tech Discussion 9 November 3rd, 2009 18:39
Voltage meter - Transmission slip NEED HELP Tomynoks OEM Tech Discussion 6 October 27th, 2007 19:59
Where Should my Voltage Gauge Read After... DIGITRUCK OEM Tech Discussion 30 June 24th, 2007 13:44
How do you read an ohm meter? ChipsXJ OEM Tech Discussion 4 September 16th, 2006 09:23
