Old July 7th, 2009, 14:25
Emerscape Emerscape is offline
Installing '01 limited heated power seats in a '00 Sport
Hey guys... scored a set of leather seats for my '00 thats in the shop getting a new head and OME suspension. Pretty psyched. Did some searching here and on JU about the installation. Looks pretty straight forward just want to make sure I get everything together before I do the install.
The seats should just bolt right in since they are from an XJ. I believe from my research that there is a plug under the carpet of the passenger side seat to plug in the power seats.
Assuming I can get ahold of the heated seat switch, where does that plug into ?
Anything else I'm missing?
Old July 7th, 2009, 14:33
ehall's Avatar
ehall ehall is offline
Re: Installing '01 limited heated power seats in a '00 Sport
the switches go in the ashtray insert in the center console
I think I got a pair with the console I swapped into my beater actually ... send a PM if you want to go look after dinner
my '91 beater rebuild
Old July 7th, 2009, 15:44
thanks for the reply. I know the switches go in the ashtray but just don't know where they plug into.
Old July 7th, 2009, 18:29
LazersGoPEWPEW LazersGoPEWPEW is offline
My 01 Sport did not have the plug under the carpet. If you don't have it you can pull one from a junkyard so you have the easy disconnect plug but otherwise you'll have to hardwire it. I hardwired mine to the battery using an inline fuse. I don't have heat though.
Old July 7th, 2009, 18:51
Whate guage wire did you use and what amp fuse?
Old July 7th, 2009, 18:56
Kittrell's Avatar
Kittrell Kittrell is offline
You can see the plug there. Its not for the seats to plug directly into. Its for the harness to plug in to, that you are missing. The seats plug into this harness as well as the switches. IIRC the part number for the harness is 56009 841AC, and it's about $500.
Old July 7th, 2009, 19:56
wow you aren't kidding. I'm heading up to pick up the seats at the salvage yard next week, I should ask for the wiring harness that connects the seats to the passenger side plug located under the carpet/moulding. Anything else?
Kittrell's Avatar
I believe thats it.
Old July 7th, 2009, 20:00
thanks man.. last question...what about the heated seat switch? I'm assuming its just one wiring harness also? I've got to call them anyway about it, so figured I'd try to get everything in one shot... man this round of fix ups is getting expensive!
Old July 7th, 2009, 22:36
Yea I had to buy that connector because mine did not have it. Cost me a dollar at the yard.
Old July 7th, 2009, 23:41
Kittrell's Avatar
The switches plug into the same harness as the seats. It runs from the passenger front plug that you see in the picture, under the passenger seat, to the console ash tray where the switches are, then finally to under the driver seat.
Old July 8th, 2009, 17:49
alright..sorry to be such a pain in the ass. Hoping to head up friday evening to pick up the seats. I called today and they said they'd take a look at the wiring harness and switches but if it was too much of a pain in the ass they probably wouldnt pull them for me. Worst case scenario, if I can't get the wiring harness I can go just hard wire it and live without the heated seats. Can someone give me a little more direction on what guage wire to use, which wires to connect with, etc.
Also, do you think the seats will fit in the back of my RX300 to transport back? I'm guessing if they have a manual tilt that I should be able to.
Thanks
Old July 8th, 2009, 20:38
I think I used 14 gauge wire to hardwire in. I just clipped the connector since pulling the harness from 97ZJ I got it from was too much of a pain.
Old July 9th, 2009, 11:05
Kittrell's Avatar
They would have to pull up the carpet to get to the harness. If they aren't willing to do it, see if you can persuade them to let you pull it yourself. It will make your installation a heck of a lot easier, as everything will just plug right in. We crammed my front and rear XJ seats into the back of a ZJ when we picked them up at the dock. I imagine your Lexus would haul them okay. Though if you are anything with your Lexus like I am with my Audi, I'd never toss seats with metal brackets bolted to them in the back.
Old July 9th, 2009, 11:06
Kittrell's Avatar
P.S. The tilt is mechanical, so you'll be able to recline them just fine.
91 limited power seats no worky jeeptorino68 OEM Tech Discussion 2 May 9th, 2009 14:13
Heated seats on '01 Limited Not working JW 4x4 OEM Tech Discussion 6 July 25th, 2007 19:58
Installing power seats ?s kemosabee Modified Tech Discussion 2 March 15th, 2007 12:49
Installing heated mirrors... andrew2516 OEM Tech Discussion 9 January 10th, 2007 07:15
