Prev Previous Post   Next Post Next
  #27
Old June 8th, 2019, 07:54
BAXJDAY BAXJDAY is offline
Re: Voltage Gauge read 19 volts - Digital Meter says 14.2
Originally Posted by Tim_MN View Post
If the dashboard voltage gauge shows 19 volts, there almost always a connectivity issue, most often corroded battery lugs/terminals, internally corroded battery wires, or a loose connection in the charging system.
Today I'm going to take a closer look. Makes sense the voltage would spike if there is a bad ground or fault somewhere. I bet you would bet me on the main cables.
Volt meter = 12 volts for a minute then ~9.5 heyisforhumans OEM Tech Discussion 2 October 9th, 2015 23:12
wiring a tach, temp, and volts gauge. mxracer5647 Modified Tech Discussion 9 November 3rd, 2009 17:39
Voltage meter - Transmission slip NEED HELP Tomynoks OEM Tech Discussion 6 October 27th, 2007 18:59
Where Should my Voltage Gauge Read After... DIGITRUCK OEM Tech Discussion 30 June 24th, 2007 12:44
How do you read an ohm meter? ChipsXJ OEM Tech Discussion 4 September 16th, 2006 08:23
