- Colorado
Hey guys... Finally got the front axle about done, just deciding on shock length.. Figured might as well do the rear seals while im at it and have fresh seals all around.
Ive helped a friend do a set years ago on his ford 9"..
. Where we had a press.. That i dont have now.
So, can it be done with the axle shafts put into the freezer and the bearings and races in the oven? Im not super keen on baking them as I can imagine it dont smell good... But if it can be done im willng to give it a shot before going shop to shop to have them press em on. What temp should do it?
Also, can heat be used to remove the old set? Instead of cutting them off?
Thanks yall
Thanks yall
