Carnage!
Hub . . . or axle . . . or locker . . . or . . . ummm . . . ????
I'm seeing that my drivers front tire has a little much negative camber. Noticed after hitting a burm at a high rate of speed. I'm hoping that the bad ball joint I already got worse vs a bent front axle
i checked and the ball joint definitely has mucho play in it
