1991-2001 Jeep Cherokee 4WD Front Suspension Kit (11 Piece)
1ATony
pepperell MA
VISIT US HERE FOR GREAT PRICES 1991-2001 Jeep Cherokee 4WD Front Suspension Kit (11 Piece)
FREE SHIPPING IN THE LOWER 48 STATES!!!
These replacement suspension parts are just what you need to ensure the safety and integrity of your vehicle's suspension and steering.
Specifications:
FRONT 11 Piece Suspension Kit includes:
(2) - FRONT UPPER Ball Joints - LH (Driver Side) & RH (Passenger Side)
(2) - FRONT LOWER Ball Joints - LH (Driver Side) & RH (Passenger Side)
(1) - FRONT OUTER Tie Rod End (Connects at Pitman Arm) - LH (Driver Side)
(1) - FRONT OUTER Tie Rod End (Connects at Steering Knuckle) - LH (Driver Side)
(1) - FRONT INNER Tie Rod End - RH (Passenger Side)
(1) - FRONT OUTER Tie Rod End (Drag Link) - RH (Passenger Side)
(2) - FRONT Sway Bar End Links - LH (Driver Side) & RH (Passenger Side)
(1) - FRONT Track Bar
Replaces dealer part numbers: 52005739, 52005740, 52005741, 52006592, 52007118, 52037849
Direct replacement
Built to strict quality control standards
Correct for 4WD (Four Wheel Drive) Models only
Worn ball joints can cause excessive front tire wear, popping or creaking in the front end, extra play in the steering system, and pose a serious safety concern. Replace loose or worn ball joints with our quality replacement. One way to diagnose a loose, or warn ball joint, is to jack the car up, so the wheel is off of the ground, then have someone try to move the wheel in and out. While they are moving the wheel check the ball joint for play, if it is moving you probably need to replace it.
Remember whenever you are replacing any front end or steering components you should have your vehicle professionally aligned as soon as possible. This will ensure proper tracking and even tire wear.
