Go Back   NAXJA Forums -::- North American XJ Association > Vendor's Marketplace > Vendor Advertisements
Old March 1st, 2019, 12:13
Roark Supply Roark Supply is offline
***Flap Discs, Flap Discs, Flap Discs!!!
…and some cut off wheels, to boot.
It’s our Flap Disc and Cut Off Wheel Combo Deal featuring Premier Grind 4.5" zirconia flap discs (German Made) and SELECT CUT 4.5” cut off wheels.
Priced at $35, this package includes:
25 – Premier Grind 4.5” x 7/8” Zirconia Flap Discs: Type 27 or Type 29 / 36, 40, 60, 80 or 120 Grit, and…
25 – SELECT CUT 4.5” Cut Off Wheels: Type 1 (flat)
Same drill as usual…Use the
COMMENTS section to let us know types and grits for the flap discs. If you leave this blank, we'll send T29 /10 - 40 Grit, 10 - 60 Grit and 5 - 80 Grit.
***Roark Supply is a leading provider of abrasives used by fabricators, as well as off-road and custom car enthusiasts.
Old March 20th, 2019, 14:10
Re: ***Flap Discs, Flap Discs, Flap Discs!!!
There's madness in the air...although we're not sure how much longer our Combo madness is going to last.
Old March 30th, 2019, 09:15
March Madness is in full swing and so is this Combo Deal.
Don’t miss out!
Old April 7th, 2019, 08:23
March Madness is winding down...two teams and two days.
The Combo Deal ends tomorrow, April 8 at midnight.
Rate This Thread:
Oktoberfest Giveaway – German Flap Discs Roark Supply Vendor Advertisements 2 October 31st, 2016 09:44
***4.5” PEARL ZIRCONIA FLAP DISCS *** Roark Supply Vendor Advertisements 1 November 11th, 2015 16:33
***4.5" CGW Zirconia Flap Discs as low as $2.49** Roark Supply Vendor Advertisements 1 June 18th, 2015 14:50
***CGW Z3 Zirconia Flap Discs – More Sizes Now Available*** Roark Supply Vendor Advertisements 1 June 1st, 2015 17:27
New Vendor - Flap Discs, Cut-Offs & More! Roark Supply Vendor Advertisements 20 May 6th, 2012 22:02
