Go Back   NAXJA Forums -::- North American XJ Association > Vendor's Marketplace > Vendor Advertisements
  #16
Old August 3rd, 2017, 17:48
JeepCables JeepCables is offline
NAXJA Supporting Vendor
Re: JeepCables - For all your battery cable needs.
With all the demands of a trail prepped Jeep, make sure your cables are doing their part! Get some JeepCables.com cables today!
Paul@JeepCables.com
Old August 3rd, 2017, 19:46
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Don't forget to mention you offer them in 2GA now.
Old August 21st, 2017, 09:24
Absolutely correct! 2GA!!!
Thanks!
Paul@JeepCables.com
Old August 27th, 2017, 07:16
splatvonzipper's Avatar
splatvonzipper splatvonzipper is offline
What specific cables are included in your kits?
Sent from my SM-N910V using Tapatalk
96 XJ - Long Arms and a bunch of other stuff
Old August 27th, 2017, 15:51
NAXJA Member 4950
The kit for my 96 came with,
3 grounds, bat- to motor, bat- to fender, motor to firewall
12v cables are, bat+ to starter, alt to included mega fuse and holder, fuse to pdc, pdc to bat+.
military style battery clamps for battery pos and neg
IMO a nice kit but I would have liked to have gotten a stud and fuse for the pdc instead of the separate fuse and holder. Would have been one less cable and connection and cleaner look.
Old August 28th, 2017, 08:02
The big reason for a separate fuse is a greater choice in fuse sizes. You can get ANL fuses all the way up to 350 AMP (the included fuse block is rated for 350). You could even do away with fuses altogether and swap in a breaker style fuse that's resettable.
-P
Paul@JeepCables.com
Old September 4th, 2017, 16:43
I'll take a set. 96 XJ zip code 92582
Old September 5th, 2017, 07:22
PM'd back!
-P
Paul@JeepCables.com
Old September 11th, 2017, 15:06
Fall is approaching! Don't be stranded in the cold.... get new cables from JeepCables.com!
Paul@JeepCables.com
Old September 29th, 2017, 07:23
Fall is here! Time to stop procrastinating and look at your cables.... Will they be ready when work when you're ready to play?
Paul@JeepCables.com
Old October 13th, 2017, 11:14
Is the spookiest thing going on under the hood of your XJ the rotting carcass of old battery cables? It's time to get some new cables from JEEPCABLES.COM!
Paul@JeepCables.com
Old November 28th, 2017, 09:45
FUN FACT:
JeepCables.com only uses SAE approved cable. I'm a technically minded guy, and I'm not into paying for things multiple times, or redoing work that's time-intensive. When I started building cables, I wanted to make sure that the cables I sold were only of the highest quality and from the highest quality materials. There's no eBay "mystery cable" used, or "copper clad aluminum" stereo wire.... just copper. Because when you're out exploring or taking the family on an adventure, quality matters.
Paul@JeepCables.com
Old December 5th, 2017, 20:02
LockeXJ LockeXJ is offline
What's your pricing for 2awg? 94 if that makes a difference
Old December 5th, 2017, 21:31
For my 2GA cables? $140. This includes the cables, an ANL fuse block and fuse, and military battery terminals.
-P
Paul@JeepCables.com
Old February 6th, 2018, 22:47
josh9mile josh9mile is offline
How much for a 4ga set without the fuse block?
Rate This Thread:
Second battery cable- what's it for? Reddleman OEM Tech Discussion 4 November 9th, 2008 22:03
oem battery cable ChipsXJ OEM Tech Discussion 1 January 24th, 2006 06:22
Battery Cable lumberxj89 OEM Tech Discussion 10 August 4th, 2004 22:01
Battery Cable Fab vintagespeed Modified Tech Discussion 11 September 10th, 2003 18:12
