Double Down
- Cincinnati, Ohio
Another crazy question I have been wanting to ask, but haven't yet. When I lifted my 97, the front has more of a hot rod stance and I knew I needed to lift up the front with spacers or different coils, but my question is how do you determine where the front should be? Should the Jeep be exactly parallel from front to back, should it have a slight downslope up front?
I have put it on level ground and I measured from the rain gutter above the driver's door to the ground and from the rain gutter at the very back to the ground and came up with about a 2" difference. Now I have 3.5" re coils up front with a custom heavy bumper and the back sits higher, so should I put in a 2" spacer or get different coils? If I need to get different coils, should I get 3.5zj's or 4.5 zj's? or something different?
Thanks for the help,
Chris
Chris
