LOTS OF Jeep and Non Jeep specific Parts and items LOOK...
RWKHausSupply
Well cleaning out a decade of stuff. This is only a smaller portion but looking to let it all go for much less than it should...
MAKE offer wont hurt, but everything is already about 50-75% off retail.
All located in Yorba Linda CA. MIGHT ship some items but you cover shipping/handling.
If you want something, please post here but also EMAIL me for best results. First come first sold.
I have pictures of each item and can email or text them. Text me for text pictures.
Robert
714-875-2414
[email protected]
Crys 8.25 rear axle master install kit NIB - 40$
Ford 10.5 mini kit (shims,seal,nut,crushsleeve - 5$
Dana 35 rear master kit NIB - 40$
Ford 10.25 carrier only install kit - 20$
Ford mini install kit - 10$
Dana 30 rev high pinion(or low pinion just no crushsleeve in kit) mini install kit - 10$
Crys 8.25 rear axle master install kit open loose just no bolts - 30$
Dana 60 mini kit (loose. bolts,pinion seal,nut and crush sleeve) - 10$
Jeep JK front Dana 30 master kit - 85$
Ford 9.75 rear master kit loose, all there except ring bolts - 70$
Dana 30 low pinion complt master install kit - 40$
Ford 9" Yukon gear 35spline master install kit with solid spacer - 85$
Dana 44 master install kit (includes Rubi style ext carrier shims) - 85$
Dana 44 TJ rubi mini install kits (2 total) - 20$ea
Ford 8.8 mini install kit (no pinion nut) - 10$
JLM704649 bearing & JLM704610 race - All New
4 koyo & 1tim/3koyo
$5
LM603049 bearings - All New
13 made in USA - 16 total
25$
LM603049 bearing & 603012 race - All New
5 total ea USA made
$15
LM603049 bearing & 603014 race - All New
8 total ea most USA made
$15
D30rev high pinion 3.07 dana gear set with open bare carrier (aprox 48k miles)
$40
D30rev high pinion 3.07 dana gear set with open full carrier (aprox 55k miles)
$50
Dana 30 spider gear set (no side thrust washers) - 5$
Dana 60 spider gear set 35spline - 10$
Will post more in next post.
5 lug and 8 lug wheel spacers - 5$ ea pr
GM 14bolt truck new in box yukon 1350 yoke with HD strap kit - $80
Dana 30 rev high pinion 4.10 gear set aprox 52k miles on it - 20$
Dana 44 HD thick (.150") steel Dana cover new in bag with bolts etc - 22$
JK Dana 44 rear open loaded carrier - 10$
Dana 30/44 yokes
1330 used - 5$
1310 used - 5$
Dana 60 yokes
1310 strap style new - 25$
1350 Ubolt style new 35$
1350 strap used - 5$
Dana 44 spider gear set NIB - 25$
Dana 30 JK front 3.73 gear set on loaded open carrier (aprox 17k miles). carrier will fit TJ XJ style fine, RG bolt holes are 7/16 opening. - 35$
Jeep TJ cat and muffler cat is good and only a few years old - 20$
Carling switch covers
25 front locker
4 arb compressor
21 rear locker
1$ea or all for 20$
Carling switches - new
14 total
5$ea
45$ all
Air locker activation solenoids
2 total
MAC made in the USA
30$ ea
Over flow tank, Jaz made I think. With bottom valve and mounting holes. includes top filter
25$
Black D-Rings NEW - 20$
4" x I think 40feet and I think rated at 40,000lbs tow strap with velcro and closed latch style holder - 40$
Hook for 2" hitch reciever - 10$
TJ OE bumper hooks with hardware - 10$
Delorean motors roll over safety valve (Ultra4 legal) - 10$
Powersteering inline filter (I think for 3/8 hose) new - 15$
2 jeep ign coils worked fine, were race spares and a new dist cap - 10$
Positive battery terminal with multiple wire outlets new and about 10' + 0 ga red cable - 25$
MSD Adapter for 2 coil redundant system w coil wires - 10$
hard alum line I think 3/8 about 10ft - 5$
KC light mounting bracket, used for anything stud mounted on to tube - 1-1/2, 1-3/4 & 2" tube - 5$
Safety knife with mounting sheath, I think its a Kabar knife, not sure - 20$
Yukon CAD axle disconnect block off kits to convert CAD to one piece axles, comes with seals for both sides.
stock 27spline kit - 20$
super 30spline kit - 20$ ea (2 avail)
Dana 35 axle bearing and seal kits - 2 total - 20$ ea kit for both sides
Yamaha Generator EF2400I new in package cover kit and wheel/handle kit over 150$ new.
45$
I'll take;
Dana 60 yokes
Jeep TJ cat and muffler cat is good and only a few years old - 20$ Cat can be used later!
I'll take;
Dana 60 yokes
Sure. I will have to meet you at my place since the muffler/cat is to big for my avalon lol.
Text me? I will be around wed and thurs.
I'll take one
"Dana 35 axle bearing and seal kits - 2 total - 20$ ea kit for both sides"
I can drive out from Whittier,
Mike
I think I either text you or PMed you. This is getting in over my head now lol. Let me know when
Looks like it has the full retaining setup. Can you toss that in a small flat rate box for me? I'll take it
Sure, please email me though so I have address and such and figure out payment and total.
Thanks
Robert
hey Rob will that 8.25 install kit fit a 29 spline? if so i'll take it.
I have someone asking for it. You want it? If so when ya going to get it? :)
i can paypal to hold it till Mark gets out there if you want but yes i want it. i need to regear my rear end badly on the DD.
Just give him the $
