I've got a set of RE drop brackets and braces that I won't be needing.
They are used, in good shape, however the hardware for them (just the bolts) is missing. I got a quote from RE for ~$31 shipped for it all, IIRC. Or you should be able to pick up some Grade 8 and Class 10.9 hardware at you local hardware store for cheaper.
RE braces go all the way back to the crossmember mounting bolts/stud, unlike the "others" that fall short.
Looking for $175 picked up. I would prefer not to ship these as they arn't light.
I can get any pictures you need, just ask.
Located in Westminster, MA.
I've also got a set of C4x4 Rock Rails. Pick them both up and I'll sweeten the deal and we'll work something out. Link: http://www.naxja.org/forum/showthread.php?t=967451
