i was thinking of mountint my shocks in this manner. weld a bracket on the leaf spring mounting pad (the pad that the u-bolts go through), for the lower and a tube from side to side of the frame rail for the upper mount. both shocks would be tilted toward each other at the top.. good ?? bad ?? what would be the best way ?. i would like to get the lower shock mount above the axle tube.
scot
scot
