'87 Cherokee Dana 44 Axle
kd5dwy
Central Arkansas
I have a Dana 44 axle that I pulled from an '87 Wagoneer from a local junkyard. I have removed the drums, pulled the axles and cleaned/painted the housing. I threw away the drums since I was going to put on disc brakes. It has an open carrier and the diff cover has a large dent in it (no damage to the gears underneath). It has a 3.54 gear ratio.
I would like $200 for the axle and you will be responsible for delivery.
I also have a Dana 30 with a bad hub. It is an '87 with vacuum disconnect (working). This axle is free for the taking. You will be responsible for delivery.
Id love it, just a little too far.
Include the shipping then.
Good point. I'll be heading to Waco for Labor Day. That means I'll be heading from Central AR down 30 through Texarkana to Dallas then South on 35E South toward Waco. If anyone wanted to meet me along the way, I would be willing to haul it along.
You know that might be do-able for me... Let me see whats up.
But if you do sell it before then its fine with me.
