LandCruizzer
- Milford, CT
After changing my t-stat and i just had my radiator bored out today still running hot. I'm having cooling problems with a salvage engine I just had installed. My engine was running at normal temps according to the guage before it shot a rod thru the oil pan. After having a 96 slavage engine with my '92 intake installed it was running hot. The when i infared back near the temp sensor(back right of the block) it reads about 30 degrees or more cooler than the guage says in the dash. Does anyone know if they are the same sensors? I did overheat a few times going up some steep grades at 8000 feet. but that wasn't untill the guage was at like 285, way off the scale. any feed back greatly appreciated
Thanx
Thanx
