To Do List
asp
Westport, MA
shall i be the first to do a list for this year?
to do:
-get axles from travis and swap them in
-design and fabricate 3 link and cross member
-weld on ruff stuff stiffeners
-make 3x3 angle iron stiffeners for the rear of the unibody
-make shock hoop things that go through the floor for the rear shocks and rework rear bumpstops
-fix lots of rust (this one could take quite a while)
-weld in 2x6 rocker replacements and tie into unibody rails
-swap transmission
-(?) design and fabricate anti-axle wrap mechanism (for the rear)
to buy:
-DOM and rect tube for 3 link and crossmember
-tube adapters
-joints for 3 link and anti-axle wrap device
-clutch
-rims and tires (haven't even decided what kind i want yet)
To do:
- weld on HD stiffeners (get rears too probably)
- swap in clutch fan (twin stock e-fans don't cut it in the summer)
- get more spare front axleshafts
I think that's it...:dunno:. There's more I COULD do, but nothing that's a requirement.
For the new Jeep, I need to
-weld on front to rear stiffeners
-get some spare front axleshafts/hubs for peace of mind
-make or buy quarter panel armor
-rocker replacements
-install bumper/winch
-steering box brace (ordered the c-rok yesterday)
-rework rear shocks/mounts
and like Colin, I'm sure there's more I could do but that stuff I'd definitely like to have taken care of...
really not bad at all :)
to do:
-dont break the jeep
-dont break the 30
-dont bitch about having an open front end
-dont throw any money at the 30
-get more spare shafts
-get more spare ball joints
actual things that should be done:
-front pinion bearings
-front driveshaft rebuild/replace
biggest thing to do:
-commit to going
all in all, i could very well blow up the front end and just decide to strip the jeep and start the stiffeners/tons before anything else happens:D
you can have the stubs and hubs from my 60
my list, decide if ill wheel the 98 at nac fest, if i do heres the list
2" bb
some sort of 31's
tcase and gas tank protection
My list...
Buy jeep without rust
Swap lift, bumpers, sliders etc. over
SYE
Gear to 4.10
Tie in front bumper better
thanks. are you gonna not use em at all becuase youre going 35 spline with yours or whatever? I'd trade ya for the stuff you want off the green jeep if you wanna bring em down on friday :)
2" bb
some sort of 31's
:yelclap:
:yelclap:
yrah im goin 35 spline stubs with flanges, also i dont have the silly socket to pull the hubs off the 60 atm or the money to buy it, one side has a stock hub that locks and unlocks fine other side has a superwinch hub that dont unlock i can get you the stuff if your goin to lobsters on the 13th
ok sure. thanks :thumbup:
Fix death wobble
get goin on that.... i had/have it so bad i didn't make it last year and i was trying for months to figure it out.
The spindle nut? or the hub dial socket caps? if it's the spindle nut I just used a hammer and flathead/chisel.
i have ni idea havent looked at it since i tried pullin it apart a couple months ago
gear to 4.10 maybe have a tru trac in my XJ44
install onboard air and air horns so i can make STROKER'S horn sound like a fart
new crosmember and skid
install e-fan
install aux trans filter and temp gauge with bigger cooler
install homebrew SYE
weld on RE lower control arm mounts with JKS mini skids
rewire my sub, and cb to get rid of interference
build cargo rack for the rear
help everyone else with there rigs
buy alot more AMZOIL
bring it home in one piece
-Install upper and lower arms
-Frame stiffy's?
-Quarter guards?
-4.56's unless I'm convinced to 4.88's
-Front Aussie?
-SYE
-Tie in front and rear bumpers
-Bumpstops
-Frame stiffy's?
-Quarter guards?
-4.88's
-Front Aussie?
-SYE
-Bumpstops
fixed ;)
to do:
ruffstuff stiffys
hd offroad front stiffys
hd front crossmember
fab up a 3 link
fab up a belly skid
stick a detroit locker in my 60
stick 60 under jeep
stick 44 under jeep
stick 35's on allieds under jeep
compete in the rcrocs clubchallenge on april 10th
want to do list:
rear tire carrier bumper
rear 1/4 protection
cage
oh and i know for a fact i am missing a few things on this list
