Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > SoCal Chapter > SoCal For Sale
SoCal For Sale ONLY Local Sale Items here.
Old September 21st, 2019, 10:48
chasdb's Avatar
chasdb chasdb is offline
NAXJA Member 3643
1996 4 DOOR XJ 4x4 4.0L, HP D44 Front Axle included
Posting for a good buddy Tim. He will add anything I forgot and his contact info next post:
1996 Jeep Cherokee XJ 122,000 Miles
5” LIFT
Wheels:
5x BFG KO2 32x12.5 x15 mounted on steel wheels, matching spare.
Not installed: 4 15x8 5 on 5.5 American Racing style aluminum wheels for axle swap.
Front:
Iron Rock Off Road Adjustable long arm kit
Iron Rock Off Road Heavy Duty Over the Knuckle Steering kit
Iron Man 4x4 Fab OTA Track Bar
Pac Racing Jeep Speed coil springs P22x220P
Dana 30 HP 3.55 open
Not installed: Dana 44 High Pinion 4.88 Gears, ARB Air Locker, T&T truss, Chevy Knuckles with Parts Mike flat high steering arms. Warn hubs plus spare. Yukon 4340 Chromoly Wagoneer axle kit, plus stock Wagoneer trail spares. Spicer U-Joints, Ball Joints. Ford rotors and hubs for 5 on 5.5 pattern. Power Stop Z36 brake pads Chevy Calipers and all ne Timken bearings. Ruff Stuff track bar and GM 1 Ton high steering. Wagoneer pitman arm. Bilstein 7100 SB12" reservoir shocks with T&J front mounts.
Rear:
Rubicon Express leaf springs 5.5
Liquid Iron Industries leaf spring slider kit.
Chrysler 8.25 rear axle ARB air locker, 4.88 Yukon Gears, 29 spline Yukon 1541 Alloy axle shafts dual drilled for 5 on 4.5(stock lug pattern) and 5 on 5 .5, disc brake kit, Ruff Stuff u-bolt kit. Bilstein 7100 thru the floor to cage,
Not installed Iron Rock Off Road truss kit 8.25.
Engine:
Stock original 4.0L H.O. I6, runs great, no leaks.
Not many miles since last tune up.
New alternator, new radiator.
Brown Dog Super engine mount kit
Odyssey battery.
2.5” full exhaust new catalytic converter
A/C and heat blows hot and cold!
Trans:
Asin Warner AW4 rebuilt by Leσn’s Transmission
Transfercase:
231HD
Advanced Adapters Slip Yolk Eliminator with Adams heavy duty drive shafts.
Boostworks shifter linkage
Frame:
T&J Performance 8pt Roll Cage installed by them.
Quick release fire extinguisher mount.
Ruff Stuff Main Frame Stiffeners.
Liquid Iron Industries front stiffeners.
T&J installed rear stiffeners.
Rear cargo rack.
OEM fuel tank skid.
Rear Ό panel guards.
Artic fluids caddy.
Bumpers:
Front Flop Shop modular winch bumper with spare horns and custom pre-runner hoop.
Rear simple modified YJ rear bumper
Not installed: not finished, Flop Shop bumper with swing out tire carrier.
Audio:
Pioneer 6800 head unit
Diamond Audio Coaxial speakers front/rear, Rockford Fostgate Amps, 2 Infinity Basslink sub woofer systems.
Roof Rack:
Baja Megamule Rack, 2 military OD fuel cans and 2 military OD water cans with Baja Rack mounts. High Lift Extreme with Baja mounts and heavy duty base plate.
Lighting:
Truck-Lite LED Headlights.
Single row light bar and rear led floods on rack not on at the moment.
Custom switch panel on cage above rearview mirror. Includes second panel not installed.
Other not installed:
Dual ARB compressor with tank and air up kit.
Superlift 10k winch new in box.
There is a lot more things that aren't listed, lots of good quality parts, hard and work done on this Jeep. Hasn't been finished and hasn't been beat on. Paint is green and black and flaking, I was going to paint it but now you can do it and choose your color!
Old September 21st, 2019, 18:56
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Re: 1996 4 DOOR XJ 4x4 4.0L, HP D44 Front Axle included
Odd... It doesn't look like my XJ. Maybe somebody snuck in the driveway last night and painted it. ( goes outside and looks in driveway)
I'd like to ask myself how well that subwoofer works.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ • 4.0 • AW4 • 231 • Modified
'87 MJ • 4.0 • AW4 • 231 • Stock-ish
SoCal Chapter President
Last edited by Bent; September 21st, 2019 at 18:57. Reason: Went out to look a driveway. Senility check.
Old September 21st, 2019, 19:21
Anak's Avatar
Anak Anak is offline
Stranger
So how much is it Tim?
Post up a price I can't refuse.
Baby it's cold outside.
Old September 21st, 2019, 20:05
MotownWeldingInc. MotownWeldingInc. is offline
$7000 obo.
714-470-6331
Have more pics of axle that was converted also and welded up.
Old September 23rd, 2019, 09:44
MickeyS MickeyS is offline
damn this is well done. wish I could sell my 96 stocker for this but don't think I'm up for the hassle. someones getting a great set up
1996 Xj 2 door 4x4 eflosd SoCal For Sale 0 October 20th, 2014 09:51
Whats wrong with my front axle? (Picture included) us74k5 Modified Tech Discussion 29 October 21st, 2013 17:31
1996 door pin help OUTKAST INC. Modified Tech Discussion 6 October 9th, 2011 19:32
1996–1999 front axle RustyFlakBurst Modified Tech Discussion 7 February 15th, 2011 14:28
XJ Front Axle and Door Zed Mikey Wanted: Private Party Only 0 February 12th, 2004 11:09
