gearwhine
- Denver, CO
I searched up a bit across some boards here and there.
I'm looking at a pair of axles from a 78 f250, you know the deal, HP44, FF 60 rear. Well I'm not wanting the complete fullsizeness of the fullsizers. I would like to cut them down a little bit, maybe an inch or 2 wider that stock axles. Then I get problems with custom axles and stuff. Even if i cut the front down to waggy length...the rear would still have to have custom axles if it's cut to the same width...unless there is a 60 somewhere with less than a 65" width....??? that way I can cut to that and use those axles.
I saw Beezil runs a 17" rim with 5" BS...8" wide I'm assuming. DO you have a frontal pic so I can see just how far those tires are protruding. Protruding...what a cool word. This seems like a decent solution to me rather than than cutting, but cutting is not a problem with me either, getting axles made is. I want as low cost as possible here.
The ONLY reason I want to cut is to keep my jeep street legal. In NJ, the whole tire tread must be covered by flares. Well, what are your thoughts... cut or just go for high BS'ed wheels. Thanks a lot _nicko_
