Can I just put high pressure rubber fuel line all the way back to the chassis and use a good hose clamp or do I need to mess with adapting these clip on ones?
I did this on my V8 MJ. I used tube adapters from Summit to make it easy and clean. The Magnum 5.2 uses the same adapters IIRC. You will need to cut the hard line and put DASH fittings on it then use the top two adapters seen in the link.
