Old May 18th, 2019, 06:30
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Re: Opinions wanted Re: Axles
https://www.naxja.org/forum/showthread.php?t=101345
Maybe a helpful link for your hunt.
Old May 21st, 2019, 07:56
Rockwood Rockwood is offline
Bummer I have with 33s and 4.56s is driveline vibes are definitely more noticeable at real freeway speeds (75-ish). Front pinion angle sucks with the lift and enough caster to not wander, so need to look into correcting that...
Old May 21st, 2019, 10:30
jonzer12 jonzer12 is offline
If you are starting from scratch, there is no 9" vs 44 debate. yes a junkyard 3rd is nothing to brag about but a 9" opens the door for huge capacity. You can grow a 9" to be just about all the axle you need without throwing everything out like you have to do with a 44. That and if you have ever worked on either a 9" is a joy to work on compared to anything from Dana.
Old May 21st, 2019, 14:40
Weasel's Avatar
Weasel Weasel is online now
Originally Posted by 4x4JeePmaNthINg View Post
I know the 9" removable casting gets bashed for issues, but make no doubt about it, a built 9 is one bad mamajama. Imo the strength of the axle housing, ease and options of customizing are highly sought after. Ide much rather build one of these than a 44. Trusses, gears, axles all readily available. The downside on a 9" is you get what you pay for. It's not cheap to build if your going all out. If your gearing, locking, trussing, it'll take almost anything.
Its worthy of your consideration.
Meh, you want to spend money on something go with a D60 and your done. 9" are neat but they are spendy to start building.
Just add lightness
Old May 23rd, 2019, 19:13
jeepjunkie97 jeepjunkie97 is offline
I actually picked up a 8.8 out of a local pick and pull, 4.10 with LSD for $125 and last weekend drove down to Maryland to snag a HP d30 for $100. Currently in the process of cleaning them up. Plan on sticking to 33s. This is my first go around with axles so I'll make sure to keep posted!
Old May 28th, 2019, 07:59
denverd1's Avatar
denverd1 denverd1 is offline
at the end of the day, OP needs to define his ultimate tire size and keep driving style in mind. the amount of work/$$$ required to run a slightly taller tire is a little crazy.
I keep going back and forth on selling my 44s and just sticking to 35s.
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old May 28th, 2019, 08:26
LJRockstar's Avatar
LJRockstar LJRockstar is offline
Funny, I was having this conversation this morning. the difference in cost between 33's, gears, a bit of fender trimming and 35's gears, rears, suspension upgrades etc. is CRAZY! The driving duties of the rig will be road trips to good technical rock crawling spots and occasional DD duty if something goes wrong with my actual DD car. I'm an east coaster, so there's many many miles between me and the good rocks. I've got Rausch Creek pretty close, but there's no replacement for Utah and Colorado even up in Minnesota there's some crazy terrain.
The more I think about it the more I want to stick to 33's. It'll make things a little bit more challenging save some $$ and keep the highway manners in check. Back in my LJ i went all types of places on 35's that people told me you couldn't go on 35's and didn't struggle all that much.
So to bring this ramble back on track... The 8.25 with good 29 spline chromoly shafts and 4.56's should be able to handle 33's with out too much issue? Should I consider bracing it? As always the ultimate goal is for it to be bulletproof.
I know the D30 with the proper upgrades should be no problem with 33's.
Old May 28th, 2019, 09:06
denverd1's Avatar
8.25 is stronger than the 30. Been running mine locked on 33's for 5 years with zero improvements.
add disc brakes to keep your axle in place if you have C-clip or axle problems and it's good to go. the stopping power is a bonus.
Chili Pepper '98
Old May 28th, 2019, 09:37
bajabronco bajabronco is offline
I picked up a Ford 8.8 with disk brakes for $125.00 from the JY, trussed it, welded the tubes, and added some Yukon 1541H shafts. Running on 37's !
Old May 28th, 2019, 14:44
freerider15 freerider15 is offline
Nothing wrong with a junkyard 9" by any means. Not many here are going to hurt a stock 3rd member.
I'd say the exact opposite. Unless it's one of the rare 35 spline stock D60's, they're not that much better than a D44 really.
A 9" can be built far cheaper than most, and beefier.
Find a 31 spline big bearing nodular housing 9" in the JY, and you'll be far ahead.
Gears and lockers are going to be similar enough between axles, but you can get used Detroits for them pretty cheap (I did). Chromos are pretty cheap as well.
An 8.8 or 8.25 would do you just fine as well.
Old May 30th, 2019, 02:25
I'm on 29spl yukons/arb,33s,4.56. Before the shafts I've taken a few surprising pucker obstacles that I had no idea a locked 8.25 could handle. It's quite capable of 35s if driven with some care, there are many that do. With that said I have full size nitto 33s and compared to a 35 not true to size your right there anyway. Btw 33s come in some awesome 10 50 options!
No axle is beyond breaking if you drive ridiculously, theres plenty examples of people proving this on purpose.
Sounds like you know where you want to go and you've got upgrade room if you like
Need opinions - Rear Dana 44 Axles - Are they good or not???? 92xjdean OEM Tech Discussion 9 December 31st, 2009 16:21
Opinions on axles from a 1977 dodge 3/4 ton Doyle NorthWest Chapter 1 November 14th, 2007 07:24
opinions wanted maineiac Modified Tech Discussion 12 April 11th, 2005 05:16
Opinions on Axles Inisadow Modified Tech Discussion 12 December 20th, 2003 06:40
welding front and rear axles need opinions BUCKYXJ Modified Tech Discussion 23 October 6th, 2003 23:31
