Ok, bought a bunch of vac fittings, clamps, and fuel vapor hose at the parts store so I could get the evap system complete. No pics of the evap system because its boring. But its complete and shouldnt give me any issues with CELs.
And then last friday (1 week ago), I got my exhaust done! However I have determined it is hitting the X frame where the stock cutout for the pipe is, needs to get clocked to the drivers side so it doesnt bang on the X frame all the damm time.
And then I did a truck thing, went to costco for some groceries with my Dad, and came back with a chest freezer.
Then I went over to Justins to use his ramp......which probably hasnt been used since this thing was last running with the 2.5L! I ran it up on the ramp enough to flex out the rear to measure for shocks. Got some shocks ordered for the rear after this.
Likely could get more but I started digging a hole on the right front in the dirt!
Looooong wheelbase! Also discovered that I needed to reroute my rear parking brake cables. Got those modifying in a different routing that should let me flex correctly without pulling them out of their holder.
So then I got my bumper prepped, and had Justin touchup a few spots on in, then go back for finishing. I then cut holes in the bumper for the LED floods, and drill and tapped the bolt holes for them:
And then I dropped it off to be galvanized. Same price for up to 600 lbs. Since this bumper weighed 55lbs you could do a bunch of stuff at once for the same price.....$310.
Got my sway bars shortened and installed, though I still need to install the keeper that holds them up out of the way.
Then I did some work on the Wildernest back window, installed a new handle with key, installed a new strut support ball, new struts, fixed messed up hinge, straightened the whole hinge. So it opens and closes correctly:
