8.25 29 spline with 4.56 and ruffstuff cover for sale
jk_surgeonfish
AZ
http://prescott.craigslist.org/pts/4881984711.html
Located in Prescott Valley,AZ
1999 Chrysler 8.25 29 Spline rear differential.
Gearing: 4.56 (good for 32, 33s)
Open Diff, NO Locker.
Drum brakes all rebuilt approximately 1 year ago.
Ruffstuff Specialties Diff cover. http://www.ruffstuffspecialties.com/catalog/825COV.html
Here is your chance to get a re-geared rear-end that would fit in an XJ, YJ. The only thing you will need is the mounts for the shocks. In addition, the rear leaf perches have been cut and rotated to accommodate a 4" lift. You will either have to use angle shims or cut and re-weld the perches to get the correct pinion angle for your vehicle.
I took this rear-end out and swapped out for a rear Dana 44 with discs and an ARB and 33spline axles.
