Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > South East Chapter > SEC For Sale / Wanted Forum
SEC For Sale / Wanted Forum This forum is for SE Chapter members to buy and sell XJ parts.
  #16
Old August 24th, 2009, 16:34
Timmy2XJS's Avatar
Timmy2XJS Timmy2XJS is offline
Re: injectors
i got mine installed and they work beautifully!
thanks man
Old August 24th, 2009, 16:50
MaxxXJ's Avatar
MaxxXJ MaxxXJ is offline
Re: injectors
the 19# injectors... whats so special about them?
Old August 24th, 2009, 17:24
nickjc13's Avatar
nickjc13 nickjc13 is offline
Re: injectors
no problem timmy.
Old August 25th, 2009, 04:19
Timmy2XJS's Avatar
Re: injectors
maxxXJ
the ford 19lb injectors have the same pounds per hour as our stockers but the 5.0 ones have a better spray pattern. it atomizes fuel better. better economy and slightly better power.
Old August 25th, 2009, 12:20
MaxxXJ's Avatar
Re: injectors
oh ok, hmm might be my next upgrade if those go out anytime in the future or my mpg isnt where i'd like it to be.
Old September 11th, 2009, 21:46
nickjc13's Avatar
Re: injectors
bump
Old September 13th, 2009, 14:21
gray_penguin's Avatar
gray_penguin gray_penguin is offline
Re: injectors
would these work in a 2.5L 4-cyl?
Old September 13th, 2009, 17:40
nickjc13's Avatar
Re: injectors
i mean they will fit if that is what your asking?
Old September 13th, 2009, 21:53
Re: injectors
I was curious if the injectors were the same in a 4.0L as the 2.5L
After looking at parts sites and the jeep catalog pdf I have, it looks like there are different part numbers for each. Not sure what the diff is, maybe the pounds per hour rating.
Old September 14th, 2009, 07:57
nickjc13's Avatar
Re: injectors
im pretty sure that the lbs are different. and if your looking for a stock injector then i would not buy these. if your motor is completely stock then these are probably not the injectors you are looking for
Old September 14th, 2009, 13:22
Cnickgo Cnickgo is offline
Do you need assistance?
Re: injectors
Look at the color of your stock injector tops. They will fit, but they may not be the right flow. I know my buddy's TJ 2.5L has grey tops which are 23lb. IIRC, you should be looking for 21lb, but don't quote me on that.
Old September 15th, 2009, 16:20
nickjc13's Avatar
Re: injectors
yes they will fit but thats what i meant the flow will not be right. they will fit though. just dont want to sell you something you dont need
Old September 22nd, 2009, 17:14
nickjc13's Avatar
Re: injectors
still have these
Old September 28th, 2009, 12:38
nickjc13's Avatar
Re: injectors
still have a few sets for sale.
Old October 13th, 2009, 14:56
nickjc13's Avatar
Re: injectors
ill take 40 shipped per set
Rate This Thread:
'96 4.0 Injectors smccollamjr OEM Tech Discussion 9 December 4th, 2008 18:20
WTB injectors for 4.0L ruff87xj Arizona For Sale/Wanted 1 June 5th, 2008 12:43
best injectors ? pbx Modified Tech Discussion 4 August 22nd, 2007 17:44
Renix Injectors for Mustang Injectors buffalomatt350 Modified Tech Discussion 1 September 7th, 2004 12:44
GM Injectors? DPC OEM Tech Discussion 5 January 30th, 2004 23:27
