Old February 21st, 2005, 09:13
Danno's Avatar
Danno Danno is offline
source for Heims, weld on tabs
anybody know a source for the larger rod ends (Heims) like 1 1/4"?
also a source for weld on shock tabs and gussets. Most of the sites I seen want several dollars apiece. Thanks, Danno
Old February 21st, 2005, 09:15
Kittrell's Avatar
Kittrell Kittrell is offline
Re: source for Heims, weld on tabs
How much is several dollars and how much would you expect premanufactured parts to cost????
Old February 21st, 2005, 09:33
Danno's Avatar
the Heims I expect to pay over $75 each for that size.
The tabs I've seen as cheap as $1 each. Just can't remember where.
Old February 21st, 2005, 09:36
BrettM's Avatar
BrettM BrettM is offline
AA for tabs: www.aa-mfg.com
vendor section on the Pirate board for rod ends
Old February 21st, 2005, 09:50
BillR's Avatar
BillR BillR is offline
Toy Jeep driver!
Also check PSC for the heims. They have tabs also.
Old February 21st, 2005, 10:05
JeepFreak21's Avatar
JeepFreak21 JeepFreak21 is offline
Try RockLogic4x4.com just cause they're good guys.
Billy
Old February 21st, 2005, 11:36
Danno's Avatar
Thanks!
Old February 21st, 2005, 12:27
Dirk Pitt's Avatar
Dirk Pitt Dirk Pitt is offline
Adam Dowling
Full Size XJ Gear sells QA1 and FK rod ends.
A different way to weld a 35 Overdriven Modified Tech Discussion 4 December 31st, 2004 06:26
Attaching front tabs to custom bumper xj92 Modified Tech Discussion 2 September 21st, 2004 18:02
box steel rockers - why leave the pinch weld? Chris S Modified Tech Discussion 14 August 30th, 2004 15:10
WOHOO! Learning to weld!!!! (few questions) Lucas Non-Tech / Off Topic 23 March 1st, 2004 08:58
weld on door hinge - reweld? mhead OEM Tech Discussion 8 September 29th, 2003 12:26
