gimike812
- Tucson, AZ
I have a ford 9in axle from a 70s 3/4ton pickup. It has 31 spline axles and I am told the big bearings. It has all the drum brake parts . Only missing the third member. The spring perches are on the top of the axle and measure44.5 center to center. That's about 1/4 inch off each side from the xj, could easily be fitted under an xj. If your interested give me an offer.
