front leaf spring pics,
92xj
Boone NC
first off I have searched and I can not get into pirate for some reason, but I have long arms now and this week putting in full widths and 38s, I am thinking about leafs up front. can anyone post some pics of the front and rear spring hangers and shackle of the front leaf spring conversion. I am just researching and looking at options, and I really cant find good pics of the mounting brackets. I have some yj leafs that I think will work for the front, so could someone post some pics or send me links, thanks alot
Inisadow said:
These are the best threads for front leaf conversions.
The only thing that hasn't sold me on a front leaf conversion is approach angle you loose a decent amount. Also I got to see dan stark's rig in the TTC thread and his front is setup insanely.
http://www.naxja.org/forum/showthread.php?t=21517&highlight=front+leaf
http://www.naxja.org/forum/showthread.php?t=8203&highlight=front+leaf+spring+conversion
This is a better thread of my build:
http://www.pirate4x4.com/forum/showthread.php?s=&threadid=139642
I broke 6 front leaf clamps again, and another main leaf on the weekend wheelin trip, my new ram bent the Tierod, I chunked off all the side lugs on the used 38s I just put on, bent the tube door I just made, and broke afew other odds and ends...
I've got 2.5" yj springs in the front now and with trimmed fenders it clears 36's pretty well...I thought I had 4" springs in it before and wanted to lower it so I swapped in the known 2.5 springs...still have about 10.5" over a stock xj.
My wife has generic 35's(actually measure 33 and some change) on a 4.5 superflex kit with lots of trimming and just beat me on the ramp at the local shownshine...only by 6 points..........we still have to bumpstop/trim hers a bit to keep from flexxing too far on the trial.
So is the leaf spring conversion worth the work? Hers will be nice on the trail, low power v6 not putting too much pressure on the stock axles, nice and low keeping the cg down...but it will be extra simple for me to put the 3/4 gear on later though with the leaf springs (just waiting for the right gear/axle combo to fall into my lap.).
I dunno, just measured from the bottom of the marker light on a stock one and the bottom of the marker light of mine and figured the difference...big numbers there, I coulda messed up...once I get past ten I start getting confused cause I cant untie my boots to count futher or I'll lose my count so I just have to imagine the toes...then its just all hypothetical past that.... :D
Do a search on here for Jeep94xj he did leafs up front. I have seen this thing in person a few times and it works real well.
if you just measured the height of the lights, then you also figured in the lift given by your larger tires. which being 36s would raise the vehicle about 3-4 inches, meaning your suspension lift is around 7 inches. that makes a lot more sense to me
hahahhahahahhaahhaaaaa.........damn.........sharp as a sack of socks I am........damn.......thanks........damn
:doh:
