7/29 trailwork
Vanimal
escondido, ca
Souske and i decided to take the long way on our way home and do a little trail work. we dug out a stream crossing and filled it with rock on the 2N04. we also put some bigger rocks on all 4 corners to deter people from trying to drive around the rocks at all. we used bigger rocks for the base so they wouldnt get washed away as easily then filled it in with some smaller rocks. hopefully this is what you were looking for. we were beat from the weekend so we only got about an hour in each, plus the drive from SD and back for each of us if that counts at all.
i know it aint much.
before
after
it was a little sunken on each side due to tire wear, hence the more rocks in those spots.
