Old April 27th, 2009, 08:56
Hubbazoot's Avatar
Hubbazoot Hubbazoot is offline
Back storage box?
Right now in the back of my jeep I have an old wooden box that carries all my off road gear and then I have my spare tire laying next to it on the other side. The problem I have is that I don't like having the box have an open top for safety and I also don't want everyone able to see into my storage box.
I'm planning on building a new storage box. Does anyone have any sort of drawer assembly pictures in back for inspiration?
Old April 27th, 2009, 09:13
Goatman's Avatar
Goatman Goatman is offline
Re: Back storage box?
I have a steel drawer exactly like you're talking about, the spare tire can sit on top of it (up to 33" I think). If you were closer I'd sell it to you cheap. It fits perfectly between the wheel wells, has the four stock floor tie downs mounted on the four corners on top, has three compartments inside. It's on heavy duty slides, works perfectly. Was custom made for the back of the XJ.
TEAM/PETTY CASHRacing........2013 Ultra4 Stock Class National Champions
Check out the TEAM Facebook page for the full story of our 2013 winning season: https://www.facebook.com/Team
Thanks to , Falken Tires, Bishop-Buehl Racing Engines, Ten Factory Axles, Brown Dog, Hooker Harness, BILSTEIN, Raceline Wheels, WARN, G&G Auto Repair/Off Road, Yukon Gear and Axle, Full Traction, Cal, Russ, James, and many, many others.
Old April 27th, 2009, 12:32
89xj 89xj is offline
the mother of all cargo area threads
http://naxja.org/forum/showthread.ph...ear+cargo+area
Old April 27th, 2009, 22:28
Hubbazoot's Avatar
Here's the idea I came up with today during lunch (no pics, just a description).
The base to it will be 48" by 32" and divided into three sections widthwise, each 16 inches wide and 10 inches high. The two sections on the right side would be 10 inch high storage drawers (not real drawers, just box in a hole type design) and the left side would be a "cubbie" that would be 20 inches high. On top of the two right portions I'd put my spare tire, and then mount my high lift on top of that. I'm still pondering how I'll handle the spare tire (I can't decide whether/how to enclose it).
Old April 28th, 2009, 08:02
20 inches high seems to be too high and there would be wasted space unless you stack things in there or carry jack stands. i use milk crates to carry stuff because its about the right height to carry coolant bottles and 1 gallon oil containers.
Old April 28th, 2009, 08:23
Hubbazoot's Avatar
I plan on using that space to put my fluids in. I may also use it to store my tool box. Mainly I want to bring it up to level to be able to put stuff on top of it.
Old April 28th, 2009, 09:50
Goatman's Avatar
Mine's pretty big, and it's 12" high. It's also pretty heavy with the stuff I carried in it, and it was a challenge finding a way to latch it so the drawer didn't bang around on the trail. You have to open it at times when you're not sitting flat on the trail (most of the time), and it can be a bear to deal with if it's too heavy.
Old April 28th, 2009, 09:55
WrenchMonkey's Avatar
WrenchMonkey WrenchMonkey is offline
NAXJA Member #771
http://www.naxja.org/forum/showthread.php?t=977669
Robert
DIRTY DEEDS, DONE DIRT CHEAP
...whatever doesn't kill you makes you stranger...
Old April 28th, 2009, 11:54
Hubbazoot's Avatar
That's part of the reason I'm goig to do two drawers. I just have to figure out a way to make sure the drawers are securely shut while I'm on the trail.
Built a subwoofer/gear storage cabinet for the back of the XJ today... Achmed South East Chapter 12 January 25th, 2009 16:25
Storage ? fasteddieyj OEM Tech Discussion 4 January 4th, 2009 09:31
Built a subwoofer/gear storage cabinet for the back of the XJ... Achmed Modified Tech Discussion 27 January 3rd, 2009 20:40
More Storage zahra2325 Modified Tech Discussion 24 August 19th, 2005 23:57
storage? vajeeper Modified Tech Discussion 8 April 18th, 2005 05:12
