Old September 15th, 2004, 10:29
Roll-over Roll-over is offline
Question coil-overs to replace stock springs
For those of you who have converted to coilovers for your primary springs what setup did you use? What did you pay compared to a traditional lift/ replacement? What were the benifits/ drawbacks after the conversion?
Old September 15th, 2004, 11:00
SeanP SeanP is offline
Re: coil-overs to replace stock springs
converting to coil overs is a very involved surgery if you want to do it right.
I did this and cut my inner fender so the CO could be mounted into the engine compartment. I fabbed shock hoops that are braced to the inner fender and "frame" and tied the hoops together over the engine with a removable bar. I used sway-a-way racerunners (remote res) with 250/300# springs with 14" travel. I sit about 8" over stock in the front with 8.5" downtravel and 5.5" uptravel. In retrospect, 16" shocks could have fit without going up thru the hood.
Benefits: Last shock I will ever buy. Totally rebuildable and easy to fine tune. Very small amount of mounting space needed for the CO on the axle which was my primary need. My narrowed D60 left very little room for the coils and my steering was interfering with the coils.
Drawbacks: Be ready to fab.
My first two trips went very well. I have an anti-rock type sway bar, but don't think I am going to install it. I am very please with how it all works
SeanP
Old September 15th, 2004, 11:53
sweet! what did you give for the s-a-w parts and do you have a wheel off pic?
Coil Springs 3" to 5"..... Paypal ready... RockRod Wanted: Private Party Only 1 June 1st, 2004 00:27
Stock Springs & Shocks btl_fed_xj For Sale: Private Party Only. XJ ITEMS ONLY 0 March 25th, 2004 20:01
Wrestling coil springs and the trac-bar!! lostcreek21 Modified Tech Discussion 5 November 2nd, 2003 19:26
6.5" coil springs 85xj Modified Tech Discussion 4 May 18th, 2003 22:48
Do I need to replace rubber coil isolator w/ new springs? jtszymano Modified Tech Discussion 5 April 1st, 2003 22:53
