So I got a good deal on a used HPP 3 programmer (50012) that had been divorced from it's previous Jeep. I still had a half tank of the 87 so when I did the power tuning, I chose the 87 fuel option. I had to drive 15mi to work and immediately heard the pinging on anything more than 1/2 throttle. I came back home and set it back to stock setting. A couple days later I refill with Sunoco 93 and then use the HPP to program for the 93 tune--still pinging. I reduce the HPP tuning to 87 and she is pinging a lot less, but still pinging. I was running a .050 plug gap(double plat autolites) due to the hotter Accel coil, cap, rotor, and Magnecors, so I reduced them back to the recommended .035 and it helped a bit. Tomorrow I plan on installing a 180* thermostat to help with the detonation. The only other engine mod is the FIPK. I'm waiting for my emissions testing before I swap in the Borlas, 99 intake, and 62mmTB from my 94, but those are going to lean out the a/f mixture by adding more air. So has anyone had success with the Hypertech programmer? I had success with the Jet stage 2 on the 94, but it won't work with the 96 OBD2. What other, if any, mods did your Jeep have? If the timing is being advanced too much, the fuel being leaned too much, can I compensate by adjusting CPS? Adjustable MAP? An excuse to buy those Ford 4 hole 24#ers?
