NotMatt
- Wenatchee, WA
Anybody got some pictures of your wagoneer front axle swap? I'm working on putting one from an 81 into my rig, but I'm a little bit confused on how to mount the coil bucket and control arm mount on the driver's side... reason being that there is a large cast spring pad there and the diff. housing is much wider on that side that the other.
Does anybody have any pics of how they tackled this problem on a Waggy axle? I've seen the thread with pictures of two seperate HP44 axle swaps, but the HP44 housing doesn't have the extra material here like the Waggy axle does. Those of you who've done this swap with coils... did you grind the cast housing back to the same width as the pass. side, or more? Did it provide enough room to mount the coil bucket and control arm mount without having to weld to the cast?
Thanks everyone for your help on this... this is the first time I've done this big of a project with my rig, it's going smoothly so far, I'm mocking up all of my mounts with cardboard and tape so I know how much steel I need to buy, just need to figure out how to work with the driver's side.
