Old September 20th, 2021, 22:11
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
AC issue?
Well not as much AC as the damn controller thingy.
97 XJ, blows cold air but only out of the 'first' defrost/recirculate position. Seems like it's not a vaccine issue as I have cruise?
What to check? Easy stuff first... Not to keen on Taking apart too many things blindly hunting for the problem
Old September 21st, 2021, 05:54
Anak's Avatar
Anak Anak is offline
Stranger
Re: AC issue?
Dayum.
I knew things were tough in Kali, but you have to get your vehicles vaccinated too?
Old September 21st, 2021, 07:03
RCP Phx RCP Phx is offline
Re: AC issue?
You need to look at the ac control switch and all 3 actuators.
Old September 21st, 2021, 07:44
Saudade's Avatar
Saudade Saudade is offline
Re: AC issue?
Well, you're correct in that it's not a vaccine issue. You do have a vacuum issue.
Check the vacuum reservoir behind the front bumper, pass side and the lines that run from it.
1988 Laredo 2wd Auto, AKA "Grey Ghost", 206K
Old September 21st, 2021, 08:13
Vince's Avatar
Vince Vince is offline
Re: AC issue?
It hasn't happened to my XJ but someone told me that a cable operated blend door can become uncoupled at the door linkage and that it was an accessible fix.
Old September 21st, 2021, 08:35
Re: AC issue?
The blend door controls the temp not the register selection.
Old September 21st, 2021, 14:31
Kejtar's Avatar
PostMaster General
Re: AC issue?
Ok.. vacuum lines then. I'll see what's going on with them. In general I do know that ai have vacuum because cruise works.
Old September 21st, 2021, 17:11
Saudade's Avatar
Re: AC issue?
The vacuum system splits somewhere around the reservoir. My '88 has the oblong tank that has 2 sides. One for the cruise, one for the vents. You may have a break in the line after the split. Check valves prevent losing all vacuum if one side breaks.
Old September 22nd, 2021, 04:04
Vince's Avatar
Re: AC issue?
I experienced 'cold only' output on my WJ on a cold morning when a plastic keyway sheared off the blend door. I guess, when I read Remi's post the memory of my WJ came to the forefront of my mind and I failed to see the important detail in his problem only being the first selection, and not cold air only.
Thanks for pointing this out. This is a real world example of Memory Bias that I believe also afflicts some AI algorithms. It's not something you can readily identify yourself so I now have a personal experience of it. This will help me appreciate the effect it has on outcomes.
Need help - Long cranking issue has turned into not wanting to run issue dudeinthepnw OEM Tech Discussion 19 January 22nd, 2019 16:07
Another overheating issue-unique-can't find post relating to this issue Stuckinca1 OEM Tech Discussion 32 August 25th, 2016 18:20
Strange idle/brake issue/ voltage drop issue stockli OEM Tech Discussion 0 May 15th, 2011 17:02
i got two problems with my 1998 XJ a trans issue and airbag issue Trey98XJ OEM Tech Discussion 12 March 29th, 2010 06:25
torque converter issue (tricky issue need some gear heads) black_goose OEM Tech Discussion 20 September 8th, 2009 21:09
