Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > The Crossover Jeeps > The New Cherokee KL (2013 - Present)
The New Cherokee KL (2013 - Present) Technical forum for the new crossover Jeep Cherokee.
Old February 1st, 2019, 23:10
bjoehandley's Avatar
bjoehandley bjoehandley is offline
Factory Lower Intake Manifold Upgrade
Well, I've learned something new on the 200Forums in the last couple days, apparently Chrysler is now putting a higher flowing lower intake on the newer P.U.G. version of the Pentastar engines. Not only will it fit the 3.6l back to 2011, but also will fit the 3.2l in the KL body Jeep Cherokee!
https://www.200forums.com/forum/58-2...er-intake.html
For the Pentastars that don't have it, this could very well be like swapping the '99-'06 4.0l intake manifold onto a '98 and older rig!
Old April 18th, 2019, 07:39
Bryan C.'s Avatar
Bryan C. Bryan C. is offline
Re: Factory Lower Intake Manifold Upgrade
I stumbled onto this post a while back. I installed the newer style lower onto my 2016 JK Rubicon last week. While I can't say exactly how much of a gain it was the engine definitely revs quicker and I downshift less on my usual morning commute grades. It was worth the time and effort for sure. Thanks for posting.
Old April 23rd, 2019, 20:35
Not a problem, when I read that it's a 100% alternative to porting the stock part, and flows better to boot, I figure I'm not the only person on here with something Pentastar powered that would find it interesting. Did you have to make any tuning changes to the computer to work with it, or did it just work? I'm debating about getting that and the MSD Coil Packs for my 2012 200 with the 3.6l when it comes time to do the plugs in it.
Old May 10th, 2019, 11:56
Bryan C.'s Avatar
No extra tuning as everything else is stock. Still have the OEM air cleaner too. After 4000 miles the PCM has adapted and seems happy with the change.
Old April 11th, 2020, 20:54
I finally got the Upgrade lower for my 200 today, bought new gasket, plugs and MSD Coils for the Pentastar in the last few weeks and have had a RPM Motorsports intake tube for the '11-'14 3.6l Avenger and 200 (think it fits the 3.6l Journeys as well) that replaces the corregated tubing and resonators these use from the factory.
For anybody wondering, here's the port shapes and the Mahle gaskets that Summit listed as OEM side for my 200, looks like Chrysler planned ahead for bigger runners, the normal gaskets fit the "Upgrade" intake on the head end where the runners are larger.
Old September 6th, 2021, 08:42
Ok, been a while since I posted anywhere on here, but the above parts are now on my 200!
Iíve only got a few hundred miles since everything was done, but I noticed a surprising change with just the coils and lower intake manifold. Here it is with everything installed with a without the plastic cover.
Then hereís where the real difference in the intake runner design is, not sure why itís got the humps in the runners on the original design on the left, but the way Chrysler got rid of them made a surprisingly big difference compared to what both Dad and weíre expecting.
Old October 6th, 2021, 19:14
Calvin Bnvds Calvin Bnvds is offline
What will be your next plan now? Are you done with this build?
99+ HO intake manifold 4.0 91-98 Upgrade Thesperd NAC Classifieds 1 September 6th, 2011 19:02
99+ intake manifold, factory hitch and some other stuff whatever For Sale: Private Party Only. XJ ITEMS ONLY 6 July 27th, 2010 18:18
Intake manifold upgrade - serpentine routing/size? Puddin99 OEM Tech Discussion 2 April 15th, 2007 21:19
Intake Manifold Upgrade jeepboy_90 Modified Tech Discussion 3 April 26th, 2006 01:03
intake manifold upgrade? willy3 Modified Tech Discussion 6 July 11th, 2004 12:20
