RWKHausSupply
- yorba linda, Cali
FOR THE MONTH OF AUGUST
Buy the best and proven in JeepSpeed, Ultra 4, and used by more daily driven jeeps than all other steering kits combined.
GO HERE TO ORDER
CE-9701 - TJ/LJ/XJ/MJ/ZJ Currectlync® Heavy Duty Steering System
GET A FREE
CE-9037X - XJ Cherokee Steering Gear Box Brace
The Currie Steering is the ONLY kit that is 100% bolt on, and allow full drop on a 4" (or more depending on exact setup) lifted XJ.
The Currie Currectlync® heavy duty tie rod and drag link system for TJ, LJ, XJ, MJ and ZJ vehicles features, a 1 ¼" diameter forged alloy drag link, and 1 ¼" solid alloy steel tie rod bar that is bored and threaded on the ends. All 7/8" thread tie rod ends with boots are included as well as the Currie heavy duty steering stabilizer bracket. This unit is a direct replacement for the stock parts. No modifications or machining to any part of the vehicle is necessary. This unit is rated at 200% stronger than the stock components. NOTE: This unit is designed to be used on vehicles with 4" of lift. It can be used on vehicles with less lift, but the vehicle must have a minimum of a 2" bump stop (over stock). Also, on vehicles with no lift, 2 of the tie rod ends may need be trimmed to achieve proper adjustment.
And then the Freebie..
Steering box braces are an essential component in extreme applications to prevent frame flex and cracking and to prevent steering slop. This brace installs easily, and will allow for the retention of the stock front sway bar on 1987-1996 models.
GO HERE TO ORDER
GET A FREE
