NAXJA is having its 18th annual March Membership Drive!!! Everyone who joins or renews during March will be entered into a drawing! More Information -
Join/Renew
Can someone tell me a part number for a compressor bypass pulley that will fit a 95 Cherokee sport 4.0l HO. All the ones I found work up to 94 or start at 96. Is there really not one for a 95???
If you are looking for the one with vertical bolts, I have one sitting in my garage I will never use (converted to YJ brackets) that I would let go for pretty cheap.
The A/C does not work, but that does not mean the compressor does not either. It is 4 vertical bolts holding down the A/C compressor to the bracket also. What did you mean by converting it to ...
