dirt_racin
- kingsport tn
* 95 model 4.0 ho 6cyl, approx. 95000 mi last october I replaced timing chain set, high volume oil pump, all new seals and gaskets, except head gasket. replaced plugs wires and dist. cap...550.00
*hp dana 30 non disc.,motive 4:56 gears, lockrite locker, moog ball joints, no knuckles.. 275.00
*dana axle shafts non disc... 100.00
*8.25 rear 4:56 yukon gears, powertrax locker, jeep liberty disc brake conversion..450.00
*231j transfer case with SYE cv style driveshaft....400.00
*front driveshaft rebuilt within last 6 months.....50.00
*aw4 transmission, have a new filter to go with it....200.00
*rough country 4.5" leaf springs.....175.00
*rough country 4.5" coil springs.......125.00
*1.5" lift shackles......40.00
*2" coil spring spacers.....30.00
*steering box with stock pitman arm........40.00
*steering box about a year old with drop pitman arm for 6"lift.....75.00
*radiator about 9 months old from advance auto........75.00
*heavy duty steering from RPM DOM tube, with hiem joints, double sheer, and drilled knuckles...200.00
*adjustable trackbar with heavy duty bracket......125.00
*unit bearings less than a year old both......75.00
*long arm kit, with heavy duty crossmember and transfer case skid.....400.00
*front bumper....150.00
*rear bumper......100.00
*4 15"x10" steel wheels.....150.00
*1 15'x8" steel wheel.....45.00
* 20g gas tank+fuel pump, less than year old ....125.00
*gas tank skid 1/8" thick with built in back up lights.....75.00
not able to post pics yet, i can email them as requested.
email [email protected]
or text 423-946-6745
located in kingsport tn.
