98 Complete Part Out
Do you by change know how much the front doors would cost to ship to 93444?
I'm in need of the top end of the 98 motor. Wanting to drop a 2001 motor in a 98. Should just need the head and distributor. Anyone know if an 01 AW4 will work in a 98?
Valve cover is off and as far as I can tell from everything I've done the head is good. The tranny (2wd) has fluid all over the back half so I'm guessing it needs an output seal and when I tried to take the NSS off it crumbled into 100 pieces. I have one from a 94 though :)
I need a master power seat switch and a master window and door lock switch if there are there. I think you said they were not though.
I need the PCM, how much shipped to 14148.
