Old April 7th, 2010, 18:46
Mr. mud Mr. mud is offline
Wide chain kit... just curious.
Considering getting another 231 case and putting a wide chain kit and sye in it. Just wondering if I just have to change the chain and gears, or if I also need a 231d case half as well. My friend at the trans shop says I do, but I haven't heard any mention of that in any of the wide chain kit threads. I want to get all the parts together and do this in one sitting instead of tearing the case down and finding that I have to order a case half.
Old April 7th, 2010, 18:52
tomcat's Avatar
tomcat tomcat is offline
Re: Wide chain kit... just curious.
just need the chain and sprockets
JB conversions has everything you need
'99 XJ sport. 4.6L stroker, AW4, 231 4.11's, ARB/Detroit, 4.5" lift on 33's. not enough armor
Old April 7th, 2010, 19:21
awesome, thank you.
Old April 7th, 2010, 20:24
joe_peters joe_peters is offline
Check your salvage yards and see if you can find a cheap NP231D.
Old April 7th, 2010, 21:13
Yeah joe, thats what I was planning on doing, maybe just swap out for the six pinion planetary too. build one case out of two or three maybe.
Old April 7th, 2010, 22:18
Frankencase! I like it!
Old April 8th, 2010, 00:58
ChiXJeff's Avatar
ChiXJeff ChiXJeff is offline
Curmudgeon
There's a difference in gear cut between NP231s in early XJs and later ones, the split is somewhere around 1992, IIRC. Putting gears from one into a case from the other makes some racket. I'd suspect that the same applies to NP231Ds as well.
ChiXJeff
Lifetime member
"Jeeps are Cherokees. All other models are wannabes." Deb. K.
Old April 8th, 2010, 01:32
5-90's Avatar
5-90 5-90 is offline
I do believe there's a light truck case that's stronger than the NP231D - the NP231DHD. I don't know how different the two are (gotta open a channel with New Process/New Venture Gear still,) but it should be findable in the late W-series and BR-series 4WD. Probably the 3/4-ton and 1-ton variants. I'd have to check my notes to be sure.
Need a wide chain for a NP231 old_man Modified Tech Discussion 7 June 28th, 2010 22:40
np 231 wide chain and supershort sye corbinafly SoCal For Sale 5 September 18th, 2009 21:42
231 wide chain conversion kewlkatdady Modified Tech Discussion 4 April 19th, 2007 19:06
NP231 wide chain kit NIB! BillR For Sale: Private Party Only. XJ ITEMS ONLY 4 May 27th, 2006 18:52
Wide chain for NP231 old_man Wanted: Private Party Only 4 February 15th, 2005 04:37
