Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > South East Chapter
South East Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Old November 7th, 2018, 11:57
PacificEd's Avatar
PacificEd PacificEd is offline
YOLO!
Headlights and heater cores
All summer I have known about needing to replace the heater core in my 1994 XJ. I'm dreading that job as everything I have read requires a lot of component removal (dropping the column, removing the dash, disconnecting the A/C, etc.). I never use the air even though the system is pressurized. I'm thinking of just removing all the A/C stuff altogether.
Today I had a headlight out and I stopped to buy a replacement that barely puts out enough light. Josh @ O'Reilly showed me a set of LED headlights and made me a deal. Now to see how much better I can see on the way home.
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
Old November 8th, 2018, 06:23
PacificEd's Avatar
YOLO!
Re: Headlights and heater cores
I like my new headlights! They are much brighter that the old stock stuff. Mark and I adjusted them a bit before my trip home and no one "bright-lighted" me so that is good. I may still have them aimed a bit low but they work good.
Old November 8th, 2018, 06:28
UNCC_99XJ's Avatar
UNCC_99XJ UNCC_99XJ is offline
Twisted Up
I'm not sure on the earlier ones, but on late models i've been able to get the dash out without having to remove the column. Lowering it to it's lowest setting was just enough.
The dash also comes out, for the most part, in one large piece. The hardest part is finding all the little screws that hold it to the firewall, and unplugging everything underneath.
-Timbo -
-'99 Sport, RE 4.5" and a few other things
-'13 Performance Blue Ford Focus ST. DD & Race Car.
-'17 Ruby Red F150 Lariat. Tow rig and occasional DD
Old November 8th, 2018, 06:55
PacificEd's Avatar
YOLO!
Yeah, and it's going to be even more fun with my big, fat hands....LOL.
Old November 25th, 2018, 14:57
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Last time I removed the dash in my old xj I didn't have to remove the column just unbolted it from the dash and let it hang down on the seat. UNCC's right the hardest part is finding all the plugs and disconnecting them as well as splitting the through firewall fuse block. Besides that you just have to discharge the a/c and drain the coolant from the heater core to remove the hvac box.
Old November 25th, 2018, 14:58
As a side note what led lights did you go with from oreilly's?
Old November 29th, 2018, 13:53
PacificEd's Avatar
YOLO!
The headlights are the ones everyone complains about on Facebook. They work well for me.
They look just like these. I probably paid too much but I needed them that day. And Mark convinced me I needed them.....LOL.
https://www.amazon.com/approved-Rect...+xj+headlights
I really wanted the High Beam Off Road LED's but they are quite a bit higher.
Old November 30th, 2018, 03:26
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
They're worth the difference in price. They were 25% last week. Not sure if they still are.
Old November 30th, 2018, 12:26
PacificEd's Avatar
YOLO!
I know but considering I needed a battery, starter and a set of plugs for my regular vehicle maintenance, they just weren't in the cards right now. I guess I'll have to wait until next year.
Old January 28th, 2019, 06:59
PacificEd's Avatar
YOLO!
For my 1994, they list an aluminum and a copper/brass heater core. The copper/brass is actually cheaper. Is there a benefit to going with one over the other?
Old January 31st, 2019, 10:34
PacificEd's Avatar
YOLO!
It looks like I'm buying another battery, this time for the 1994. I got 5 years out of a 500 cca battery.
Old September 25th, 2019, 12:36
PacificEd's Avatar
YOLO!
It looks like I'll be getting ready to replace my heater core soon. It's starting to get cool out at night and I need to be able to defrost the windshield and interior glass. It's marginal at best now.
I found RockAuto has great prices on either an aluminum or copper/brass heater core. I think I'm going with the copper/brass one made by APDI/PRO For $36.
The AC system is still sealed but doesn't blow cold. I never use the AC. Since I have to open the AC system up, would it be worth reconnecting it? I don't use it but are their any benefits to having it functioning?
I have thought about deleting everything with the AC system to clean up the engine compartment. I would just use a delete pulley in place of the AC compressor. It just seems like the added expense of recharging the system just isn't worth it.
What do you guys think?
Old September 27th, 2019, 06:01
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
If you don't use it, I see no reason to put it back together after you drain it. KP helped me with my heater core in my '01, and like Tim said in earlier posts, we didn't remove the dashboard. I remember dropping the column as low as it would go and removing the pax side seat so we had more room to work.
One thing we went to the store for was weatherstripping for house doors. We reused the heater box, of course, but the foam seals on that box had decayed to the point we couldn't reuse most of it. Weatherstripping was the closest approximation we could find to what Jeep used OEM, and it was readily available.
Are you going to have a wrenchfest one of these weekends?
Dirk DeYoung--Member #176
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2006 XK (TOW RIG) 2000 XJ (Project Doppleganger)
Old September 27th, 2019, 06:21
PacificEd's Avatar
YOLO!
I think it would be fun to do one since they were always a lot of fun and we always got a lot of stuff done. Plus we ate good too. Jack is playing football and it absorbs a ton of my time right now.
It's looking like he won't play Jr Pro basketball and Olivia isn't playing basketball anymore so things may free up in mid-November. I really need to get the heater core done before that though.
I've always seen everyone take the dash loose so it could be pulled back enough to pull the heater HVAC box out. Did you have to undo the dash so it could be maneuvered around?
Old September 27th, 2019, 10:13
Cottontail's Avatar
Three-De Off-Road
Yes, we pulled the dash loose.
I'd be up for a Wrenchfest. Love having a bunch of guys together tinkering on 3 or 4 Jeeps in a day.
Rate This Thread:
Lost headlights in XJ & Dodge after using accsry heater?? CameronB OEM Tech Discussion 0 March 10th, 2013 22:41
01 heater cores not fitting rockclimber OEM Tech Discussion 14 November 19th, 2012 20:18
Dealer vs. NAPA prices-heater cores cnugent OEM Tech Discussion 5 September 25th, 2010 08:14
Heater Cores and Fan w/clutch motroutmo MWC For Sale/Wanted Forum 0 September 11th, 2008 11:50
WTB 4.0 and 4.2 cores sipx Arizona For Sale/Wanted 0 March 17th, 2007 08:00
