cheap jeep parts
99NCXJ
Belmont, NC
I'm tired of looking at this stuff so it all has to go. I'm dropping prices like walmart here.
From 97 XJ...
Dana 30 unit bearings 20.00 each
Dana 30 brake rotors, some rust from sitting but plenty of life once cleaned up 5.00 each
Dana 30 brake calipers with good pads 10.00 each
29 Sp. 8.25, 3.55's, open carrier, with parking brake cable and block 100.00
Manual rear doors with professional tint, near perfect shape, 20.00 each
Rear hatch (near perfect) minus handle and latch 40.00
Rear hatch glass with defrost 10.00 (from 89 xj)
Parts from 97 dash (cluster, glove box, dash pad, sides, ect) 5-10 bucks depending on part
(2) 97 steering coulumn with key, 20.00 (one is tilt, one isn't)
(1) drivers side air bags (dark grey) 40.00
Pass side air bag assy. (dark grey) 40.00
Cargo area glass, 2 are tinted and 2 aren't, 10.00 each
Cargo area carpet set, light grey (very nice) 10.00
(2) Auto trans shifter 15.00
Headliner, light grey (very nice) 15.00
(2) AW4 computer 20.00
(2) 4.0 computer 20.00
Rear fender flares (painted black) 10.00 each
Rear bumper, Rhino lined 15.00
Rear bumper end caps, slight scuffing (painted black) 5.00 each
polly gas tank with sending unit 20.00
polly gas tank without sending unit 10.00
stock rear leaf springs 35.00
(2) steering shafts (firewall to steering box) 20.00
(2) rear drive shaft with joints 15.00
misc. interior plastic trim (light grey) 5-15 bucks depending on part.
97 front header panel with some damage but repairable. 10.00
(2) black grills (very slight damage) 10.00
Full engine bay wiring harness 20.00
Set of light grey XJ seats from 97. need cleaning. 20.00 each
XJ front wiper arms 5.00
brake pedal assy. 5.00
front wiper motor assy. 5.00
gas pedal assy. 5.00
factory xj soundbar with speakers and covers. some fabric needs glued back down but nice shape otherwise. 15.00
Factory roof rack no cross bars. 10.00
A/C / Heater box with fan. 25.00
Parts from 85 J-20 truck...
Frame 50.00
Cab with dash (no dash pad), under dash A/C, good windshield and rear slider window. 100.00
(5) stock steel wheels, 8 on 6.5 pattern. 3 of them have good year work horse tires with around 90% tread, one has dry rotted mud tire, one has no tire. 50.00 for all.
front turn signal covers 5.00 for both
side marker lights/turn signals 10.00 for both
Do you have the little plastic piece that holds the console lid down? I have the little button you press, but the latch is broken off.
i need everything from the hatch to the wiper arm so it just leaves the bare shaft sticking out of the hatch....is it a metal hatch? if so whats the total including being shipped to 37921.
