desertfox1023
- Burlington, NC
Well I'm selling my 8.25 axle. It is a 95 axle with 99 XJ 29 spline shafts, carrier, 3.55 gears, and newer seals. The Carrier has been Lincoln locked and is fully welded. It also comes with brand new brakes in the box and the original drive shaft. It is a great swap into a pre-97 XJ's with the D35c has it is a direct bolt-in with no modifications needed except for changing your drive shaft length. The original one does come with it so you know what length you will need. Located in Charlotte / Graham, NC. So to some it all up 8.25, 29spline, locked, 3.55 gears, and new brakes 275obo.
