1998 XJ 4.0L, AX15, NP231, D44/D44, Arizona
redneck
1998 Jeep Cherokee XJ "Rubicon" 4.0L inline 6, AX15 manual transmission, NP231 transfercase, Built Jeep TJ Rubicon Dana 44 axles, manual door locks, manual windows, cruise control. Arizona Jeep its entire life, bought from Bill Luke Chrysler Jeep in 1998. I am the second owner and got it from a longtime family friend that used it as a commuter and had only engaged the 4wd a hand full of times on dirt roads. I have done all the modifications myself from bone stock when I got it.
This has been my daily driver for over 5 years now and it has never let me down. When I got the jeep I replaced the entire cooling system and charging system and steering components (including pump and hoses) with new NAPA parts. I replaced all of the clutch components and installed a new Crankshaft Position Sensor while I was there. I built this XJ as a daily driver/weekend warrior with all the good stuff so I wouldn't have to worry. I used this Jeep as a commuter to West Texas last summer without hesitation or issue. It is the most fuel efficient (17-18 mpg) and happy driving down the highway at 70mph with the cruise control on and the AC blowing.
This is the 3rd Cherokee XJ that I built and intended for it to be my last. I am only selling because I am stepping up to a JK for more space.
With that being said, I am including all of my XJ spare parts in this sale. This includes but is not limited to; lights, axle shafts, hardware, fender flares, u-joints, relays, hub bearings, alternator, power steering pump, hoses, sensors, etc... Most everything is in boxes or plastic totes. Do with it what you want but, it comes with the Jeep!
Please understand that this is a 20 years old XJ that has been used off-road but, not abused. I know that I am forgetting some of the things about it so just call or email me with questions. Asking $8500 or best offer. Please, be reasonable with the offers and do not waste my time with low ball offers. If you are a Jeep or XJ guy, you know how much this build took. I am willing to deliver to the states surrounding AZ for the cost of fuel.
602- zeven9nine- ten eightyseven.
1998 Jeep XJ Cherokee 4.0L, AX15, NP231, D44/D44, 196K miles
AXLES
FRONT TJ Rubicon D44
• Yukon Zip air locker
• Yukon 4.10 gears
• Yukon chromo shafts
• Solid Axle Industries diff cover
• Timkin Bearing and seals
• Timkin Hub bearings
• Centric Parts 120.67045 Premium Brake Rotors
• EBC Brakes Yellowstuff brake pads
• Iron Rock Off Road axle tube Sleeve kit
• Gusseted UCA bracket
• ¼" plate skids on LCA brackets
• MOOG V8 ZJ Steering
• Old Man Emu steering stabilizer
• Braded Stainless Steel extended brake lines
REAR TJ Rubicon D44
• Stock Rubicon 4.10 gears and locker w/LSD
• Serious Offroad axle truss
• Ruffstuff D44 axle swap brackets
• High clearance shock mounts
SUSPENSION
• Old Man Emu 3" coil springs
• Old Man Emu 2.5" Dakar Leafs
• JKS boomerang shackle
• Rustys off road lower and upper adjustable control arms
• JKS track bar
• JKS quick disconnects
• Old Man Emu Nitrogen Sport shocks
• TAD drive shafts (Deer Valley local) with 1310 to 1330 conversion joints
• Advance adapters SYE
• 31x10.50-15 BFG KM2 w/ Discount Tire certs
• Spidertrax 1.25" wheel spacers for stock silver Ecco aluminum rims
Engine
• 99+ intake
• Jeepers Creepers 62mm throttle body
• AFE intake
• Ford Fuel Injectors
• APN Header
• 2.5" custom down pipe
• Magnaflow Muffler - Nice and mild with no cabin drone on the highway
• Brown Dog engine mount plates and mounts
• New clutch and all components about 25K miles ago
Armor
• JCR Deluxe front bumper with hoop and Unibody Tie-in Kit w/Steering Spacer
• Plate cross member behind front bumper holding winch under radiator
• JCR Gen 1 Crusader rear bumper with unibody tie-in bracket and integrated lower quarter panel armor.
• JCR Crusader rock sliders
• JCR transfer case skid
• JCR Gas tank skid
• Rusty's Off-road engine/transmission skid plate (not installed)
Other
• Rugged Ridge Heavy Duty 8500lbs winch
• Smittybilt 2810 Low Profile Roller Fairlead
• ARB on board air with 1.5 gallon tank
• European export tail lights (have stock as well)
• Rigid Industries 30" combo light bar
• Rigid Industries Dually Series Flood cubes
NAXJA 5-90 Battery cable upgrade
• ScanGauge next to A-pillar
• Truck-lite knock off LED head lights
• Alpine CDE-HD148BT CD Receiver
• Infinity Reference 6032cf 6.5-Inch Speakers
• Polk Audio AA3085-A MM840 DVC 8-Inch Subwoofer
• Subthump Cargo Stealth Enclosure
• Alpine MRV-M500 Mono V-Power Digital Amplifier
• FireStik FL3-B Three Foot FireFly Antenna
• FireStik MK-174 Hood Channel Mount
• Uniden PRO520XL CB Radio
• Prime 4x4 Illuminated Rocker Switch Panel with labeled switches
• Lund Catch-All Front Floor Liners, 2nd Seat Floor Liner, and Rear Cargo Liner
• Boostwerks Engineering 231 HD Shift Linkage (still in box)
New pictures as of today... There are more parts than in the pictures that I need to round up as well.
Tires rotated and balanced today, ready to go to a new home. Make me an offer! I've got a deal working on a JK and need this to sell.
