Colorado Association Of 4 Wheel Drive Clubs 2011 Raffle Bronco
jwtrapper
Wetmore, CO
Okay I know its not an XJ but it is for a good cause to keep our trails open here in Colorado. I'm sure some of you have seen it already on Colorado4x4 but for thoes of you that don't go to the site I thought that I would put it up here.
This is going to be the 2011 Raffle Vehicle Tickets won't be available untill Feb. 2011
Our Donations So Far:
T&T Customs: Special Treat
Warn: Warn Winch
Tuffy Security: Security glove box and center console
Ruff Stuff: $250 worth of Parts
Seal Brothers: Paint Job
SSR Auto: Paint and supplies
Canon Tuck: 205 transfer case
Nemesis Industries: Cage, Custom Dash and some special touches
Battlement Fabrication: Rear Bumper and Tire Carrier
PRP Seats: Two of their Daily Driver bucket seats
Premier Power Welder: On Board Welder
Poison Spyder Customs: Rear Gas Tank Skid Plate
Craig Fire and Safety: First Aid Kit and Fire Extinguisher
Royal Purple: All Fluids
O'Reilly's Auto Parts: Dress up stuff for motor
Spidertrax Off-Road: 9" Rear Axle Housing
Toms Bronco Parts: Power Brake Kit and a new Starter
Bronco Hut and ididit Inc.: Chrome Tilt Steering Column
Hi-Lift Jack Company: Hi-Lift Jack
Deaver Spring: Front Coils and Rear Leafs
James Duff: Rear Quarter Guards
Painless Wiring: Complete wiring harness
Crawlertech: Crane Hi Clearance Knuckles and Assemble Front Axle
Off Road Design: Doubler Kit for 203/205
Front Range Custom Coatings: Custom Coating
D&K Engines and Machine Shop: Machine Work/Engine Rebuild
Austin Automotive: Engine Rebuild
Randy's Ring & Pinion: Yukon Axle Shafts and Lockers
Magnaflow Exhaust Products: Muffler and tip
PSC Performance Steering Components: Power Steering Pump, Hoses and Steering Box
Bestop: Bronco Soft Top
Predator 4 Wheel Drive: Assemble Rear Axle
Tomken Machine: Front Winch Bumper
Nick's Trix: Some Bronco Goodies
Odyssey Battery: PC1500 Odyssey Battery
KC HiLiTES: 130w Black Daylighters
TrueHi9: Hi Pinion 9" Third Member
Ballistic Fabrication: Ford 9" Semi-Float Axle Flanges
Red Line Powder Coating, Inc.: Sand Blasting and some Powder Coating
Complete Off Road: Dana 44 Warn Premium Locking Hubs
Bulldog Winch: Bulldog Winch Rigging Kit
4 Wheel Parts: 37x12.5x17 Pro Comp Mud Terrain
Addicted Off Road: Rock Sliders
Power Tank: 10lb Power Tank System
West Coast Broncos: Extreme Duty Motor Mounts and Power Steering Brackets
Wild Horses Four Wheel Drive:Brake Lines and Hoses
B.C. Broncos: 5.5" Front Coil Springs
Don Allison: np203 Transfer Case and Some Great Bronco Wisdom!
Dave (ManTruck:) Windshield and Install
Ridge Runners: Hood and ECU
Four To Go 4x4: Exhaust and Recovery Strap
M.O.R.E. Mountain Off-Road Enterprises: Body Lift
Ron Davis Radiators: Aluminum Radiator
The Streetrod Manufacturing Co., Inc.: Rear Disk Brake Setup
Elite Audio Solutions: Complete High End Sound System
MSD Ignition: Distributor and Wires
Gregs 4WD Xtreme: C/B Radio and Antenna
Twizted Engineering: Front Brake Setup
4WD Factory: Front 4.56 Gears and install kit
Bushwacker: Cut Out Fender Flares
Copperhead Fabrication: 203/205 Doubler Truss Bracket
4WD 4Wheel Wheel Drive Hardware: Grant Steering Wheel
Bronco Design: Roadster Door Inserts
Stage 8 Locking Fasteners: Locking Header Bolts and X Lock locking spindle nuts
Mac's Custom Tie Downs: Custom Tie Downs to keep it safe on the trailer while traveling around
NAPA Auto: Rebuild Kit for NP205
Off Road LTD: RCI Street Belts
JB Custom Fabrication: Custom Shifter Knobs for the Triple Stick
Moab 4x4 Outpost: M4O Half Doors
RJM Injection Tech: EFI Harness
Bronco Graveyard: H4 Headlights, Harness and Bezels, Tail Lights and Bezels, Windshield Washer Setup, Wiper Arms and Wipers, Bronco Emblems.
Dakota Digitaland Brady's Garden Center: Bronco Digital Gauge
Rockstar Kustomz USA: Edelbrock Water Pump
Middick's Locksmith Shop: Lock Work
Columbine Automotive Products: Plug in Heavy Duty Jumper Cables
Daystar: Body Mounts, Bump Stops, Winch & Jack Accessories
Master Pull: Snthetic Winch Rope and Fairlead
ORO Off Road Only: LiteSPOTs Under Chassis Kit
Colorado Classic Broncos: Lokar Shift Linkage and Kickdown Cable
If you would like to donate to our build please contact me. We have a great list of parts but we are still in need of a few items to complete the build.
So we now have it back down with us and got to work on it right away. Pulled the cage out and pulled the body off.
We have to build a crossmember for the transmission and transfer cases and then we will pull every thing off of the frame too.
Loaded up on the trailer to start the body work!!
Its getting closer.
That thing is gonna look so sexy..
Looks good!...but I'm not sure I would trust that cage for a serious roll...
But, yes other wise I'll take 1 kthnxbye! :D
I don't get it? What is it that you wouldn't trust?
There is no back seat, this is not a "family cage" it's made to protect the driver and passenger and is well built to do that job.
Sorry, guess it just comes from having to scrutinize things structurally with school.
What I meant can kind of be illustrated in the picture:
I know there is some re-inforcement with the plating, but plating tends to cause big problems stress wise (can actually make things worse). I think I remember seeing something of the same sort happening to an east coast rig (styling is very much the same), but I can't find the picture.
Either way, just my $.02....but i'm overly critical. :D
So all the joints fail at the same time in a roll? I don't think so. Critical, not so analytical.
I think he is getting at the fact that the entire cage structure leans back. Normally you would have a cage lean in like this /---\ whereas this cage is like this /----/
I know a cheese dick way of showing it but I see what he is getting at. The rear spreaders don't seeem designed in a fashion as to prevent the cage from collapsing down on itself.
There is always someone who thinks they know better than the next guy...... This is an awesome project and this cage will work for what it is intended! Keep your negative comments to yourself! You do good work Justin but I am sure I can pick apart what is left of your XJ!! Many people have put ALOT of time into this project for the sake of our hobby!! Help us help you or STFU!!!
Wow dude, really?
And yeah, I can see what freerider is saying about the cage. That being said, I'm sure the cage is more than strong enough and safe enough. It is definately a different design then I've ever seen before and looks pretty cool.
I'm sure he wasn't in any way trying to be disrespectful towards those making the rig or discrediting their knowledge/work.
Maybe you just need a hug?
6a00df351f789488330133f5e45c90970b-800wi
Geeze... It looks bad ass... But really That cage will protect. Its not a full out buggy and don't think it will see trails that it will be on its lid or side alot. I mean if it turns out way nice i wouldn't take it on the most extreme trails.
But I can't wait to see it finished.
Wow dude, really?
You have not seen the cage nor do you know the guys who built it! It pisses me off when someone tries to piss on anothers parade! This project is being done to help YOU........... jwtrapper and many other awesome people have put countless hours, donations and cash into this thing for your benefit........ the least you could do is say thank you instead of pick apart something you have only seen in a picture here!
I wasn't the one picking it apart so calm down there check nuts, and quite frankly neither was freerider. Go eat some cookies and calm down.
