Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
  #16
Old December 19th, 2019, 02:22
WestfieldMX5 WestfieldMX5 is offline
Re: Need some Megasquirt opinions
Do you have one of the renix plugs? I could try create it in KiCad and make a batch of pcb's that have both connectors, one on each side.
Old December 21st, 2019, 12:10
old_man's Avatar
old_man old_man is offline
I have several Renix ECU's, but I think I can source them. I do lots of pcb layouts as part of my profession, so I kind of want to do it myself.
Tom Houston - Former Colorado Chapter Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old December 27th, 2019, 17:37
So basically you want to copy my design even before it's finished.
Old December 28th, 2019, 08:34
dano_nd dano_nd is offline
Drama. Yaaaaaaay.
Sent from my SM-T720 using Tapatalk
Old December 28th, 2019, 09:52
RCP Phx RCP Phx is online now
You guys could work together to accomplish what sounds like a common goal!
Old December 29th, 2019, 05:09
Originally Posted by dano_nd View Post
Drama. Yaaaaaaay.
No drama Dano, just an observation. I'm pretty down to earth on these things.
I've finished mine already and it works.
I'll let the OP do his thing
Old December 30th, 2019, 19:25
John(XJ)Jeep's Avatar
John(XJ)Jeep John(XJ)Jeep is offline
The Renix plug is a Delphi 56 pin. Lot's of them used on 80's GM's as far as I can see. Maybe something there you can utilize?
Rate This Thread:
Refurbished PCM/ECU or go Megasquirt? rockosocko OEM Tech Discussion 6 August 10th, 2016 11:51
Tachometer on XJ with Megasquirt? 88JeepXJ Jeep Street and Performance 5 August 27th, 2009 16:24
Megasquirt blazin Jeep Street and Performance 6 June 4th, 2008 09:51
Megasquirt XJ wolfgraj Modified Tech Discussion 23 March 2nd, 2008 18:27
Megasquirt anyone? karter74 Jeep Street and Performance 5 May 11th, 2005 07:46
